TSB lists?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Light-tower, Sep 30, 2007.
  1. Sep 30, 2007 at 1:56 PM
    Light-tower
    Light-tower [OP] Well-Known Member
    I just purchased a 2005 Tacoma 6 shift 4L TRD 4x4 4 door and it has 57000km so the warranty will soon expire. Given my average drive, I estimate that I only have 1-2 months left.
    I have the TSB printed out for the rear spring suspension and will call the dealer tomorrow about it:) but was wondering if there is a list available that I can look at and scrutinize.
    Thanks.:gossip:
  2. Sep 30, 2007 at 7:51 PM
    Light-tower
    Anyone have a comprehensive list to TSB or recall notices for the 2005 Tacoma's?
    Specifically Canadian TSB?:(:canada:
    EDIT. JUST FOUND THIS LIST BUT IT'S THE AMERICAN. I ASSUME IT'S THE SAME:
    PHP:
    TSB Number Issue Date      TSB Title
    SSC50C MAR 05    Recall
    Park Brake Pedal Cable Lock Nut Torque
    TSB Number
    ST005R
    -01 MAR 07    Steering/Suspension Vehicle Pull Manual Supplement
    TC003
    -07 MAR 07    Drivetrain Driveshaft Replacement Precautions
    AU001R
    -06 FEB 07    Audio System Quick Reference Diagnostic Guide
    EL003
    -07 FEB 07    Air Bag Systems Repair Manual Supplement
    PG001R
    -06 NOV 06    Electrical Battery Maintenance and Testing
    BO022
    -06 NOV 06    Interior Driver's Side Lower Dash Panel Poor Fit
    NV009-06 SEP 06    Body - Upper/Lower Windshield Ticking Noise
    EG046-06 AUG 06    Engine - Underhood Rattle Noise at Idle or In Reverse
    TC006-06 JUL 06    M/T - Grinding/Hard to Engage 4WD Low
    TC004-06 JUN 06    M/T - Clutch Pedal Squeaking Noise
    PG011R-05 JUN 06    Fuel System - Fuel Injector Cleaning Procedure
    DL001-06 JUN 06    Drivetrain - Diffcult To Shift Into/Out of 4WD Low
    NV004-06 MAY 06    Interior - Front Seat Squeak Noise
    EG033-06 MAY 06    Fuel System - No Start In Extreme Cold/MIL ON/DTC'
    s Set
    EG043R
    -05 MAY 06    Fuel System MIL ON/DTC's/No Start in Extreme Cold
    BO017R-03 APR 06    Body - Interior Trim Panels/Garnish Loose
    ST004-06 APR 06    Steering - Flutter at Highway Speeds
    EG025-06 APR 06    Emissions - MIL ON/DTC'
    s P043E/P043F/P2401/P2402/P2419
    EG021
    -06 APR 06    Exhaust System Ticking Noise Between 2,000-2,500 RPM
    NV003
    -06 MAR 06    Body Front End Rattle/Squeak on Bumps
    AU001R
    -05 FEB 06    Audio System Amplifier Won't Turn OFF/Battery Drain
    BO001-06 JAN 06    Body - Front/Rear Window Runs Deformed
    SU002R-05 DEC 05    Suspension - Rear Suspension Slap/Squeak Noise
    BO022R-04 DEC 05    Restraints - Seat Belt Extender Availability/Application
    SS003-05 NOV 05    Audio System - CD Player Skip Verification
    EG059-05 NOV 05    Engine Controls - MIL ON/DTC'
    s P0171/P0174/P2195/P2197
    BO014
    -05 NOV 05    SRS/Interior Seat Cover Replacement Caution
    EG048
    -05 NOV 05    A/T Controls MIL ON/DTC P2742 Set
    PA002R
    -02 OCT 05    Paint Paint Stains Under Rapgard
    PG005R
    -03 SEP 05    Tires/Wheels Spare Tire Carrier Operation
    EG037R
    -05 SEP 05    Fuel/Emissions MIL ON/DTC's P0456/P0445 and P0441 Set
    SS003R-02 AUG 05    Antitheft - Diagnostic Tester Immobilizer Function
    EG034-05 AUG 05    Exhaust System - Excessive Sulfur Dioxide Odor
    AX004-05 JUL 05    Body/Frame - Skid Plate Vibration
    NV007-05 JUN 05    Body - Front/Rear Popping/Knocking Noise on Rough Roads
    EG045R-04 JUN 05    Engine Controls - Entering VIN When Replacing PCM/ECM
    BO004R-05 APR 05    Body - Water Leaks Onto Front Floor
    EG014-05 MAR 05    Cooling System - Radiator Cap Inspection Procedure
    SS001-05 MAR 05    Computers/Controls - CAN Interface Module Initialization
    PA003R-02 FEB 05    Paint - Refinishing Bumper Cover
    BO026R-00 JAN 05    Body - Water Leaks to The Interior
    TC002R-03 DEC 04    Engine/Transmission Controls - Resetting ECM Memory
    AC009-04 DEC 04    A/C - Sensor Inspection Procedures
    PA005R-04 DEC 04    Paint - Iron Rust Contamination Repair
    TC009-04 DEC 04    A/T - A340 Solenoid Identification
    TC006R-03 DEC 04    A/T - New Fluid Introduction/Compatibility
    CRIB141 OCT 04    Paint - Chip Resistant Coatings
    CRIB145 OCT 04    Paint - Paint Codes
  3. Sep 30, 2007 at 8:13 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    where did u find all of those? i'd love to see what all is out there for the 07's
  4. Oct 1, 2007 at 4:11 AM
    Light-tower
    Most of them are not major problems at all but a comprehensive 'how-to' in rectifying certain problems.
    Here you go:
    http://www.alldata.com/TSB/60/056020aF.html
  5. Oct 2, 2007 at 3:20 PM
    Light-tower
    Update
    TSB SU006-007 addresses bottoming-out problem
    Getting new leaf springs installed today :)
