TSB on frame corrosion recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmettx, Apr 18, 2015.
  1. Apr 18, 2015 at 1:45 PM
    jmettx
    jmettx [OP] Active Member
    2005 TRD V6
    Do any of you have the full TSB and procedure (not the recall notice) for doing the full frame replacement on the 2005+ Tacoma? If so, can you reply with a link or PDF? Thanks, very much.
  2. Aug 20, 2016 at 7:01 PM
    mxben1980
    mxben1980 Member
    Ben
    2005 base tacoma long bed double cab V6 4x4 Auto
    hydraulic snow plow
    Sorry for bringing back to life this old thread but i'm also in search of the frame replacement procedure. I just bought a salvaged Tacoma (blown engine) with a rust free cab and i plan to switch cab with my actual DCLB cause it has started perforation at the rocker panels. I think having the frame switch procedure would be helpful for doing the cab switch the easiest way and without forgetting anything. Thanks!
  3. Aug 21, 2016 at 5:14 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Do you have any pics of the perforations in the rocker panels. Could be an area susceptible to corrosion that others members can watch for.
  4. Aug 21, 2016 at 10:54 AM
    mxben1980
    mxben1980 Member
    Ben
    hydraulic snow plow
