TSB on rear brakes? worth doing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Gadget, Aug 19, 2014.
  1. Aug 19, 2014 at 5:43 PM
    Mr.Gadget
    Mr.Gadget [OP] Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    So my 2012 is getting close on warranty and I have the rear brake squeal
    going real slow or rolling stops like at a fast food joint.
    Is the TSB worth doing and will it fix it, or is there any difference in quality.
    THey say it will take a day and they need to check if it is covered or falls under the TSB and could turn me away and charge me for #1 service fee to check problem #2 full brake job.
    Kind if a catch 22 they can not and will not say anything without pulling it apart.
    Pulling is apart risk screwing things up more, having the same thing happen as has been reported and so on.....
    Is it better to let it go and just do them myself when needed or the sound gets too loud.
    any input?
    Thoughts?
  2. Aug 19, 2014 at 6:28 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    I just has mine done last week. Took 90 minutes and I they replaced everything. They ordered the parts ahead of time since I was in a couple weeks before for an oil change. I took the mechanic for a ride around the block and he heard the squeak several times and didn't question it at all. I've not heard a sound from the rear brakes in a couple hundred mile since it was done.
    For me it was worth an hour and a half of my time.
  3. Aug 19, 2014 at 7:52 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Had it done on mine, worth it to me, no more brake noise in traffic.
  4. Aug 20, 2014 at 4:45 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Please post the TSB # and if you can a copy of the repair ticket parts replaced.
    Thanks
  5. Aug 20, 2014 at 6:22 AM
    Kilo Charlie
    Iowa
  6. Aug 20, 2014 at 9:29 AM
    D4D Hilux Dude
    D4D Hilux Dude Well-Known Member
    Darren
    Arvada, CO
    2011 4x4 Double Cab TRD Offroad
    TRD Supercharger TRD Catback Exhaust Ziebart Rust Proofing Additional Bed Ties 2012 Indicator side mirrors
    Does anyone know if the updated brake shoes work on a tacoma that did NOT have the TSB done or can they only work with the updated drum?
  7. Aug 20, 2014 at 9:32 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Your dealer sounds like a bunch of hardos. If it exhibits the characteristics of the TSB why go the route of potentially charging you? Seems kinda soft on their part.
  8. Aug 20, 2014 at 11:21 AM
    Kilo Charlie
    Iowa
    As I mentioned here it appears to me the only thing really changed was the pad material.
  9. Aug 20, 2014 at 3:19 PM
    Eyedoc2020
    Eyedoc2020 Well-Known Member
    Greg
    DC suburbs
    2012 TRD Off Road
    Had mine done over a year ago. No more squeaks, and no problems since.
  10. Aug 20, 2014 at 4:59 PM
    Haskett039
    Haskett039 Well-Known Member
    Rob
    Ontario, Canada
    2012 TRD Alpine White
    After mine started squeaking at 30000kms I found the TSB and spent a shit load of time arguing with my dealership that I qualify and got the work done at the 50000kms mark. less than 25000kms later the brand new "better" brakes started doing the exact same thing the originals did and are actually squeaking worse. My opinion is try it if its free and under warranty, if not spend some $$$ and buy proper parts and do it yourself cheaper.
  11. Aug 21, 2014 at 3:49 PM
    yakker1982
    yakker1982 Active Member
    Bay Area, CA
    12 DCLB 4WD V6 Sport
    Just picked mine up from the dealer. Have been arguing with them for 6 months now to have them do the TSB on the rear brakes (they squealed for about 12,000 miles now - at slow speed breaking).
    First two times I took it in, they either told me that it was just dust and/or they couldn't duplicate it. This time, it was squealing as I pulled in to the service center and I made sure that the rep that came out heard it.
    Picked it up today. Looks like they replaced the drums, shoes and gasket.
    Tech also wrote down that he felt vibrations from the front when braking on road test (I knew is was there but it was super light so I was surprised he felt it). So they machined the front rotors too. Now I have no braking vibrations and no squeal from the back!
  12. Aug 21, 2014 at 7:10 PM
    bassinman
    bassinman Well-Known Member
    Gilbert Arizona
    11 Prerunner SR5
    Tint, WeatherTech mats, Differential Breather Mod, Fogs on anytime mod, Seatbelt chime disabled, glove box led's, Rear spring TSB
    Had my 2011 done with 1300 miles on her. Squeal was obvious with light braking at very slow speed. People would stare when I went through the drive thru. Dealer replaced shoes, drums and gaskets. Also, your dealer is being a turd--I would notify corporate that the douchebag is threatening to charge you for checking to see if your vehicle qualifies for a TSB. Don't think corporate will appreciate the dealer's ABUSE of the process. Good luck.
  13. Jul 15, 2015 at 5:45 AM
    Tj0hn
    Tj0hn Well-Known Member
    Arkansas
    Stock TRD Sport 4x4
    Just found this thread. My 2012 with 35000 miles is doing this.
    This is the verbiage from the TSB itself..
    APPLICABLE WARRANTY
    • This repair is covered under the Toyota Basic Warranty. This warranty is in effect for 36 months
    or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
    • Warranty application is limited to occurrence of the specified condition described in this
    bulletin.
    © 2012
    Does that mean I have to get this done before I hit 36000/3 years?
    Pretty sure I hit 3 years already.
  14. Jul 15, 2015 at 6:51 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    You can try but most likely they won't allow it since it starts from the in service date. Most likely since yours is a 2012, the in service date is 2011 depending on what time of the year is was purchased. That's what they pulled with my wife's Rav4 with a different TSB for it.
  15. Jul 15, 2015 at 7:01 AM
    chas44
    chas44 Well-Known Member
    Virginia
    2012 TRD Sport
    I had this done on my 2012 at 35,000 miles about 2 months ago without questions asked.
  16. Jul 15, 2015 at 8:32 AM
    Tj0hn
    Arkansas
    Stock TRD Sport 4x4
    That's what I am scared of.
    I hooked up with a dealer and will drop it off this afternoon, parts should arrive tomorrow and have it back by tomorrow. I gotta have it back by Saturday because I leave TDY sunday. :goingcrazy:
  17. Jul 16, 2015 at 12:24 PM
    Tj0hn
    Arkansas
    Stock TRD Sport 4x4
    Took my truck in and dropped it off. In service date is 5/9/2012, so I am roughly two months over. Service manager is currently waiting to see if they'll grant a grace period. All parts are in and ready to go, just waiting on the go ahead. :pray:
  18. Jul 16, 2015 at 12:31 PM
    awhitfield4
    awhitfield4 Well-Known Member
    Fort Worth, TX
    Any chance of this extending to the 2013MY? Mine has started doing this within the last 1000 miles. Any other 13-15 having the issue yet?
  19. Jul 16, 2015 at 1:00 PM
    TacomaMike37
    13' DCLB MGM
    Mine is having this issue as well. Will ask have the dealer look at when it comes time for them to do the oil change next month. Ill let you know what they say and if you could keep me up too on your end regarding what your dealer says.
  20. Jul 16, 2015 at 1:03 PM
    Tj0hn
    Arkansas
    Stock TRD Sport 4x4
    Not sure. My bosses 2013 does the same thing also.
    The TSB is attached. States only 2011-2012.
