TSB or non-tsb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaTSP4, Nov 3, 2009.
  1. Nov 3, 2009 at 10:30 AM
    TacomaTSP4
    TacomaTSP4 [OP] Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    how do i know if i need a TSB AAL or non-tsb and whats the difference?
  2. Nov 3, 2009 at 10:31 AM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    i have a 2007 tacoma 4x4 accesscab
  3. Nov 3, 2009 at 10:35 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    any 05-08 (currently) AC or DC prerunner/4x4 that is still under the 3 yr/36k and has a 3 leaf pack w/ the TSB part number on it. some have been able to get it done on 09's as well
  4. Nov 3, 2009 at 10:46 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
    The toytec AAL should fit both. Or just look under your truck.
  5. Nov 3, 2009 at 10:46 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    The difference is: with the TSB AAL, the truck can handle more weight without bottoming out, handles better and feels more solid with the extra leaf. And it adds about 1 1/2 inches of lift in the rear.
  6. Nov 3, 2009 at 5:18 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Didn't want to start a new post since ther are a number of them on the subject already but what approach did some of you take as far as getting the tsb for rear leafs done? Did you call the dealer and make an appointment? What did you tell them the problem was?
    Or did you call or e-mail toyota directly? I have an 09 TRD Sport 4x4. The springs have the same part numbers as the tsb.
  7. Nov 3, 2009 at 5:21 PM
    The_Hodge
    SC
    either way works, but calling the 1-800 number also logs the complaint and provides goodstatistics for them to add the 09 to the TSB like they did w/ the 08's
  8. Nov 3, 2009 at 5:30 PM
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    Have any of you who had the rear spring tab done experienced the low speed shimmy afterwards? I installed a Alacan aal on my 06 tacoma along with the shims which raised the rear 2.5" and had a shimmy with that.
  9. Nov 3, 2009 at 6:02 PM
    eddie885221
    eddie885221 Member
    Tuscaloosa
    08 Prerunner SR5
    none yet!
    stupid question, whats TSB?
  10. Nov 3, 2009 at 6:10 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Technical Service Bulletin. There are never stupid questions.
  11. Nov 3, 2009 at 6:14 PM
    yodavic61
    yodavic61 New Member
    british columbia,canada
    silver streak access cab sr5
    map lights on with dome light,magna flow exhaust,weathertec floor mats,toyota side bars,super bright led lights.
    Not a stupid question. TSB stands for Toyota Service Bulletin.
    Not a recall, only a response to problems customers are having with their vehicles.
  12. Nov 3, 2009 at 9:29 PM
    JKD
    JKD Well-Known Member
    You only need it if you are experiencing problems carrying a normal load up to the capacity of the truck. Excessive bump stop contact, for example.
  13. Nov 4, 2009 at 7:08 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    Check out this link for how others got their TSB AAL approved.
    How I got the TSB on my 2009
  14. Nov 4, 2009 at 7:25 AM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    Aside from the part numbers is there a noticable difference between the old parts and the new parts they install for the TSB? I am dropping my truck off tomorrow and I want to know what to look for when it's done. Not that I don't trust the dealership, you just gotta "c.y.a." sometimes.
  15. Nov 4, 2009 at 8:13 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    Here are some pix for ya. CHeck part numbers for reference. The most obvious is that you now have 3 leaf springs, and with the TSB AAL(add-a-leaf) you will have 4
  16. Nov 4, 2009 at 8:16 AM
    tomonian77
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Did they replace your shocks as well?
  17. Nov 4, 2009 at 10:58 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    Oh yeah... I forgot about that part of the TSB. Since I have the TRD Off Road, I already have the upgraded shocks.
    Only non TRD's get upgraded with Toyota Factory Billsteins with the TSB.
  18. Nov 4, 2009 at 12:46 PM
    KnobleOne
    KnobleOne Member
    Larry
    Upsate New York
    09 DblCab Longbed TRD
    I have a 2009 Tacoma 4X4 DoubleCab. I use it to two a 21' travel trailer that has a dry weight of 3600 lbs. I am trying to get the rear leaf spring TSB done to stiffen up the rear end. I talked to the dealer who was clueless about the TSB so I printed it and showed it to them. This did not work. They siad they have no authority to do the TSB and claim to have spoken to the district rep who said the TSB cannot be done to the 2009.
    In our conversation the dealer claims that the TSB has already been applied to the 2009 Tacomas. My Tacoma which included the sport suspension has a 3 leaf spring set - two full leaf springs and a third short (helper spring). The dealer claims that pre-2009 Tacomas only had a 2 leaf spring set - two full leafs and no helper spring. Discussions on this site lead me to believe that getting the TSB done would result in a 4 leaf set - 3 full leaf springs and 1 help spring.
    Is my understanding correct? How many leaf springs did the 2008 Tacoma have compared to the 2009 Tacoma?
  19. Nov 4, 2009 at 12:51 PM
    flyjpa
    flyjpa Active Member
    Texas
    ‘19 Cavalry Blue TRDOR
    Work-in-progress
    Had mine done a few weeks ago.. Just told service manager that while hauling a load the truck felt very mushy (technical term) and bottomed a few times. Other than that, no questions asked.
    Non-TRD Pre-runner DBL Cab Taco...got the Bilsteins (all four) and a new leaf spring pack, not just an added lead.
    Hope this helps.
  20. Nov 4, 2009 at 12:51 PM
    BSP4x4
    BSP4x4 Guest
    Your dealer is giving you a line of bull, however he is correct in saying the TSB DOES NOT cover the 09's (Yet) keep your fingers crossed, call toyota corp and file a case number ..this may help...search other threads on hear for some hints!
