TSB PROBLEM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlalien, May 2, 2011.
  1. May 2, 2011 at 8:42 PM
    dlalien
    dlalien [OP] Well-Known Member
    Jose
    North Hollywood CA
    08 TRD Sport DCLB 4WD, Tow package
    hey I got the rear TSB done and yes I got the 4 leaf springs on each side and each side has diferent part numbers. Everything seams fine other then the driver side sits shorter then the passenger side. From the leveld floor to the bottom of the fender is 36"1/2 on the driver side and on the passenger side is at 37" 1/2. Its 1 inch diference. This can't be normal what can I do, has anyone had this before. I plan to call the dealer tommorow.
  2. May 2, 2011 at 8:53 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    They might have placed them on the wrong sides. I know when I did my own personal truck I double checked the part numbers. They are side specific, meaning one part number is for the drivers left side and the other for the pass right side.
  3. May 2, 2011 at 8:57 PM
    Tonka Tacoma
    Tonka Tacoma Well-Known Member
    Eric
    Plattsburgh, New York
    2009 Regular Cab 4X4
    3'' Toytec Suspension Lift, Dick Cepek DC-2 Rims, BF Goodrich All Terrain TA's, Bug Guard, Side Window Visors, Back Window Visor, Diamond Plate Kobalt Tool Box, Stainless Steel Exhaust Tip, Stainless Steel Plate Frames, Stainless Steel Stubby Antenna, "TACOMA" Front Windshield Banner, Toyota Tundra 4X4 Tailgate Badge, And TRD Box decals.
    I Thought all Stock 2nd Gen. Tacomas Sagged A Little On The Driver Side? I Have Heard It Called "The Taco Lean"? I Didn't Think It Was A Whole Inch Though.
  4. May 2, 2011 at 8:58 PM
    Range 44
    Range 44 Well-Known Member
    Georgia
    2008 FJ TTE
    Full tank of gas?
  5. May 2, 2011 at 9:07 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Taco lean
    Normal
  6. May 2, 2011 at 9:08 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Not sure if this will help you but I think the correct part numbers are:
    8210-04570 PS, and 48220-04210 DS
    Yes, with a full tank of gas there is a noticeable lean to the drivers side.. but for some reason this is fixed by adding a 10mm spacer to the front DS shock and not the rear, which has never made complete sense to me I must confess since the tank is in the rear.
    But in any case if it did not lean previously it reasons that it should not lean now. It is possible to put the leafs on incorrectly, wrong side. That seems plausible to me.
  7. May 3, 2011 at 2:35 PM
    dlalien
    Jose
    North Hollywood CA
    Yeah right now I have a full tank of gas but I don't think that would matter the truck should be designed to carry a full tank. I will check the front and see if theirs a diff in the front. I didn't check if their was a difference before I got the TSB done.
  8. May 3, 2011 at 8:22 PM
    Sawick
    Sawick Still not worthy!
    JB MDL, NJ
    16 TRD Sport
    T4R TRD Pro Wheels, LED lights, Tonneau Cover, ICI running boards, AVS window/bug
    I almost have the same problem, but I have added the Toytec TSB AAL also. One side sits almost 1" higher in the rear. Not sure if it was like this pre-TSB AAL or not, as I did not measure.
  9. May 3, 2011 at 8:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If they swapped shocks, they may have mixed them up, as to what side they go on.
  10. May 3, 2011 at 10:20 PM
    dlalien
    Jose
    North Hollywood CA
    Well i checked the front and they are both even, I called the dealer and they said they have to get approval to look at my truck because i got the tsb done when i still had warrenty and now i dont. I tought you grt 1 year warrenty on every service parts you get at the dealer. I will fallow up tomorow and see what they say.
