TSB question...cannot be answered from the sticky threads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Oct 5, 2008.
  1. Oct 5, 2008 at 11:56 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    i bought my truck used from honda 47000 miles on it, it now has 53...can i still run tsbs or nee? i bought a extended warranty for it too...i heard some people say they call the dealership and they dont ask questions they just do the work for them...am i screwed?
  2. Oct 6, 2008 at 12:01 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Call the dealer. Since you bought the truck at a honda dealer, is that where you bought the extended warranty? Or through one of those non dealer warranty companies?:eek:
  3. Oct 6, 2008 at 12:05 AM
    Marioso
    San diego Ca
    throguh honda
  4. Oct 6, 2008 at 12:07 AM
    genxer36
    Sean
    Bethlehem,GA
    Toyota may not accept that warranty. It sounds like any warranty work will have to be done at Honda. I would check with the Toyota dealership anyway.
    No worries. My 05 Tacoma has 96,000 miles on it & still going strong.
  5. Oct 6, 2008 at 12:09 AM
    VeeRFour05
    VeeRFour05 Active Member
    If you have the problem, and you have warenty, yes they will perform the TSB on it. A lot of people seem to not understand the difference between a TSB and a recall.
    A TSB (Technical Service Bulletin) is a publication to help out the technician with diagnosing a vehicle, showing a common problem, or making them aware of an updated part. Just because there is a TSB on the vehicle does not mean that you can just go in and get the work performed for free. You have to have the problem first, and have warenty second.
    With a recall, as long as your vehicle qualifies, they have to perform the work for free, but recalls are generally only for safety issues.
  6. Oct 6, 2008 at 12:12 AM
    genxer36
    Sean
    Bethlehem,GA
    His regular warranty ran out. And with a Honda extended warranty, I doubt Toyota is going to accept it.
  7. Oct 6, 2008 at 12:12 AM
    Marioso
    San diego Ca
    i understood all that my question was based on miles and my warranty...i can get it to bottom out and i feel the tailgate cant handle much im wondering if i can still get tsb done
  8. Oct 6, 2008 at 12:14 AM
    VeeRFour05
    If your warenty will cover it, yes. Like I said the TSB is just a tool for the tech to use. If the Honda dealership is the one doing the work, you may want to make them aware that there is a TSB on it, since chances are they won't know or check. If you can find a copy of the TSB you may want to print it off and bring it in for them to use, otherwise they should be able to look it up with alldata. Your extended warenty is through a different company, not Honda. Even if you were to buy it from a Toyota dealership the extended would probably be through a different company.
  9. Oct 6, 2008 at 12:15 AM
    genxer36
    Sean
    Bethlehem,GA
    TSB would cost you money if you are not under warranty. You can always ask, it never hurts to ask.
  10. Oct 6, 2008 at 12:33 AM
    Marioso
    San diego Ca
    whats hondas warranty do for me
  11. Oct 6, 2008 at 12:39 AM
    genxer36
    Sean
    Bethlehem,GA
    It may not be worth the paper it is written on. This is something you need to do some leg work on. You should take the paperwork to a Toyota dealer & see if it is valid there. If not then I would go back to Honda & make sure it is valid there.
  12. Oct 6, 2008 at 12:49 AM
    Marioso
    San diego Ca
    gotcha
    what paper work? like the booklet i got for it or the papers i got the day of the buying of the car
  13. Oct 6, 2008 at 1:04 AM
    genxer36
    Sean
    Bethlehem,GA
    Yes. If that is the extended warranty info.
  14. Oct 6, 2008 at 8:55 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    as far as i know, the tsb only works up to 36k miles, regardless of extended warranty. i talked to toyota hq about the bent tailgate tsb and they also said that was only up to 36k miles, eventhough i had the 100k mile warranty from them
  15. Oct 6, 2008 at 9:37 AM
    Marioso
    San diego Ca
    that sucks i havent had anything go wrong but i wouldnt mind an extra leaf haha are they cheap to put in?
  16. Oct 6, 2008 at 11:04 AM
    The_Hodge
    SC
    u can get a pro comp AAL for pretty cheap
  17. Oct 6, 2008 at 2:06 PM
    Angus_NB
    Angus_NB Well-Known Member
    Riverview, NB, Canada
    '08 Tundra DC SR5 4x4
    My truck was not covered under Toyota's extended warranty. So far it hasn't covered any TSB, missing mud flaps or molding falling off. The list of what it does cover is a lot shorter than what it doesn't cover.
