TSB Questions :frusty:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05yota, May 13, 2008.
  1. May 13, 2008 at 12:50 PM
    05yota
    05yota [OP] Well-Known Member
    Beaufort SC
    05 Dbl Cab Long Bed
    Alpine IVA-W205 Double din TV, 10in Memphis shallow mount sub, Rockford Amp, 23in Akuza Bounce Rims!!!
    How do you know if your truck needs something listed in the TSB, and I was reading one of the TSB's and it said it is only good during the 3yr 36000 mile warrenty but i purchased the extended warrenty from toyota when i bought my truck in 2005 and its still good am i still covered??:frusty:
  2. May 13, 2008 at 12:59 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    yes, you are still covered if it is an actual Toyota warranty.
    Don't worry about whether you need the TSB. You should be able to come here and complain and we'll tell you if there is a TSB to fix it.
