TSB - Rear leaf spring noise.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wilsonpj, Jul 22, 2009.
  1. Jul 22, 2009 at 3:06 PM
    wilsonpj
    wilsonpj [OP] Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Anyone have a odd ticking sounds on the TSB leafs when going over bumps? Sounds like they need some lube or something, kinda like they are rubbing just a tad when they first start to compress and again once they are about to go back to their stationary location. I can't really describe the sound that well. Not sure what to do to get rid of that.
    Edit: almost a creaking sound.
  2. Jul 22, 2009 at 3:12 PM
    sr5boy
    sr5boy Well-Known Member
    tallahassee florida
    06 tacoma 4x4
    demudflapped, debadged, relocated the 7-pin, 3'' fatbobs garage lift in front
    nope my axle just goes straight to the bump stop. BOOM, i bottom out with one person in the back seat.
  3. Jul 22, 2009 at 5:43 PM
    Alex352
    Alex352 Well-Known Member
    Alex
    Oregon
    07 Tacoma Dbl Cab
    http://www.tacomaworld.com/forum/2nd-gen-builds/281569-alex352s-build-thread.html
    hmmm mine does this but i dont have the tsb done. i do have a 1.5" block in the back though. let me no if u found a way to quiet or get rid of the noise.thanks
  4. Jul 22, 2009 at 6:09 PM
    Krp2nite
    Krp2nite Well-Known Member
    Mine was doing it after the TSB too. I just sprayed them down with some WD40 on afternoon and it went away. May not last long......so far so good.
  5. Jul 23, 2009 at 8:28 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    Maybe I'll give that a try. Did you spray the whole leaf?
  6. Jul 23, 2009 at 8:50 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    You are still bottoming out after the TSB?
  7. Jul 23, 2009 at 9:26 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    No, no bottoming out issues. Never said there was.
    The leafs are making a weird creaking sounds when they flex. I was wondering if anyone had the same problem after getting the TSB done.
  8. Jul 23, 2009 at 10:57 AM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I dind't have the TSB done, but mine squeak. Before I got on this site and found out about the TSB, I went to the dealership and they looked at it and SAID they replaced somethin, but I think they just lubed the leafs up cuz it came back after a month. I spray mine with a pressure washer and it makes it stop for a month or so.
  9. Jul 28, 2009 at 12:16 PM
    TacomaMuddin2007
    TacomaMuddin2007 Well-Known Member
    Alex
    Statesboro, Georgia
    2007 Toyota Tacoma SR5 4x4
    One Piece Westin Sportsman Brush Guard, 2.25 Ready Lift Leveling Kit
    im not too sure what TSB stands for but i also have that nasty creeking noise in my tacoma's leaf springs. I have used white lithium grease to lube it up before and it seemed to help out a bit because i think that it is due to the metal on metal rubbing. but please inform me if there is a permanet solution. I cannot stand the sound and i pesonally think that it makes Toyota look bad even tho it does not mechanically effect the truck.
    Thanks
  10. Jul 28, 2009 at 12:49 PM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Look under there and make sure they didn't screw yours up like mine. They put the mounting bolt in backwards and it was rubbing the frame and squeeked on every bump. The had to take mine down and re-install the pack.
  11. Jul 28, 2009 at 12:53 PM
    TacomaMuddin2007
    Alex
    Statesboro, Georgia
    dang i will have to check that out. it should not be that way... at least i hope that it is not...is there anything else that it could possibly be?
  12. Jul 28, 2009 at 12:57 PM
    wilsonpj
    Pete
    2006 DC, SB, OR
    Which way should the bolt face?
    (----- = The bolt
    Body (---- Leafs Nut Inside
    or
    Body Nut Leafs -----) Inside.
    Does this make any sense?
  13. Jul 28, 2009 at 1:04 PM
    TacomaMuddin2007
    Alex
    Statesboro, Georgia
    no... im guessing that if u can see where the frame has been being scratched up then yeah its the wrong way so i am taking it
  14. Jul 28, 2009 at 1:07 PM
    hillbillynwv
    Fairmont, WV
    The head of the top mounting bolt should be near the frame not like mine in the picture. I sprayed WD-40 to stop the squeeling till it was fixed. The original springs were mounted right, this was screwed up when they first installed the new 4 leaf pack.
  15. Jul 28, 2009 at 1:07 PM
    wilsonpj
    Pete
    2006 DC, SB, OR
    Yea that would make a lot of sense, ha ha. I'm just being lazy I don't want to go look right now. Good info though.
  16. Jul 28, 2009 at 1:13 PM
    TacomaMuddin2007
    Alex
    Statesboro, Georgia
    i wish i could look right now but i dont think my boss would lake it too much if i went outside and got my khakis and polo all dirty just because i wanted to look what what causing my truck to squeak. haha.
    i have not had anything done to my taco's leaf springs so hopefully if did not come from the factory like that
  17. Jul 28, 2009 at 1:16 PM
    hillbillynwv
    Fairmont, WV
    I would guess your squeeking is from sand/mud between your leafs. Power washer should fix it.
  18. Jul 28, 2009 at 1:20 PM
    SLOH
    SLOH Well-Known Member
    Scott
    Los Angeles
    07 SR5, dc long bed speedway blue
    2.5 Icon c/o's and 3" AllPro rear suspension kit, 17" XD Series Addict w/ 285/70/R17 BFG KM2's, K&N 63 Series CAI, 13.5'' JL Sub (13TW5v2-2) and 500w Rockford Fosgate amp, limo tint all around, cat back banks exhaust with no muffler or tip, blue dash light mod, "taco" 3rd brake light mod, blue dome-light mod, cb radio and 4' firestik antenna, blacked out hoodscoop(thanks randy), Total Chaos UCA's
    Yeah mine started doing that about a year ago after i started off roading seriously. It creaks all the time now, when i come to a stop, when i leave a stop, kinda get used to it. I hasn't really bothered me enough to fix, i just figured the leaf springs needed to be greased up but haven't done it yet
  19. Jul 28, 2009 at 1:30 PM
    TacomaMuddin2007
    Alex
    Statesboro, Georgia
    yeah that is exactly what mine does. i hate it so i just turn the music up loud so i cant hear it
  20. Jul 28, 2009 at 5:26 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I have a reg cab, stock 3 spring, over speed bumps rated at 30 mph mine goes "clack clack" or so from 25 mph to 35, Havent gone faster on em yet. I'm gussing now..... it could be the pack retainer clip or whatever its called. the serve- less writer..... errr service writer says its normal. I wanna slap him for tacoma neglect and the crime of excessive public stupidity.
