Tsb rear leaf springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robbie77905, Jun 24, 2011.
  1. Jun 24, 2011 at 5:06 PM
    Robbie77905
    Robbie77905 [OP] New Member
    William
    06 Tacoma SR5 TRD-offroad, six speed
    ARB full replacement, 3'' front lift, 33'' maxxis mudders
    Im new to the cite, and have seen and heard a lot about a "tsb rear let spring mod" but I dont quite understand what this is. Dose the dealer do it or is it something you buy? Any help would be great thanks.
  2. Jun 24, 2011 at 5:16 PM
    JKD
    JKD Well-Known Member
    It's a TSB, a Technical Service Bulletin. Some owners have experienced a 'harsh ride' when carrying a load that is within the stated load capacity of the truck. Toyota has a fix for this, which is covered under the factory warranty if the truck is not outside the mileage/time limits.
  3. Jun 24, 2011 at 5:19 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    To add on to what JKD said, they'll replace your 3-leaf pack for a 4-leaf pack. Get it if you haul stuff. Use the search button to find the thread w/ the actual TSB. Good luck!
  4. Jun 24, 2011 at 5:35 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    3Yr/36,000, he's over on both counts.
    The 06 would most likely get shocks all around, bump stops and the 4 leaf rear.
