TSB Rear Leaf
Discussion in '2nd Gen. Tacomas (2005-2015)' started by worldtec, May 17, 2011.
  1. May 17, 2011 at 12:29 PM
    worldtec
    worldtec [OP] Member
    El Paso
    2011 TRD Sport white...
    Stock for now....
    How many of you have done the TSB for the rear suspension? I have a 2011 TRD sport dual cab. Did the ride get to stiff? did the yride change allot? let me know the dealer is going to order my parts and I just want to hear some opinions of people who have done it...... thanks in advance.:confused:
  2. May 17, 2011 at 12:33 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Just had it done on my Off Road. Yes it does stiffen up the ride a bit, but I personally like it. I though the factory springs were to soft. Its a truck, it should ride like a truck.
    It also raised the rear about a inch, so now its prime for a easy lift.
  3. May 17, 2011 at 1:04 PM
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2011 Tacoma Sport 4X4
    265-70-17 Goodyear Duratracs. Pro Comp 17x8 8089's. Bilstein 5100's front and rear (front set to 1.75). 1/4 inch spacer--driver side. TSB rear leaf springs. WeatherTech floor liners. EGR in-channel vent visors. RDS tool box.
    Did some experimenting today on my brand new Tacoma DC Sport 4X4 w/towing package (1185 miles). I loaded the bed up with 500 lbs. of free weights. Unloaded, it was 36 inches from the bottom of the fender flare to the ground. With the 500 lbs., the clearance dropped to 33 3/4 inches--2 1/4 inches of sag.
    Then, I proceeded to go for a drive to check it out under load. As soon as I was on the highway I could tell something wasn't right. The steering was very "soft" due to the weight on the rear and the ride was very rough--I could feel every bump in the road. Next, I proceeded to take it down a semi-rough dirt road. I could feel it bottoming out. I got out and checked the bump stops and you could see where it had been hitting.
    Needless to say, I'm very disappointed and wish I had known this before I purchased this truck. I will be pulling a heavy boat with the truck and have plans to purchase a small travel trailer. I'll be meeting with the service manager at the dealership where I purchased the truck on Thursday at a customer appreciation dinner. I plan to mention the problem then and we'll see what happens.
  4. May 17, 2011 at 1:27 PM
    worldtec
    El Paso
    Stock for now....
    yeah well I'm in the same boat. The dealer is ordering the parts for the TSB on mine. so hopefully I will not regret it do it. I know what you mean with the truck sagging. I had a grille, tents, chairs all the stuf for camping and it droped about 2 inches more or less..... sucks that I paid 27G's and this is happening.
    well I'm looking to buy an RV so hopefully with the new leaf I could pull it with no problems do to sagging..... I'll keep you updated..
  5. May 17, 2011 at 1:29 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    From the sounds of it, you do not have the TSB leaf springs. The problem you described is the very reason they exits.
    I think they don't put the TSB leaf springs on from the factory due to the stiffness in rid. They know us Americans prefer comfort over usefulness. They figure if someone actually uses their truck as a truck, then they will give them the upgrade.
  6. May 17, 2011 at 1:48 PM
    Bolt79
    White Springs, FL
    Yea, I've got the three leaf version. I'm going to hit 'em up for the upgrade. Maybe they won't give me any crap. By the way, my dealer is Valdosta Toyota in Valdosta, GA. Anybody else on here had any dealings with them on this or any other issues?
  7. May 17, 2011 at 1:58 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    you wont be disappointed. i did mine and even the TSB pack is a little weak w 500lbs in the bed. if you get a camper youll prob end up doing helpers or air bags anyway.
  8. May 17, 2011 at 2:00 PM
    pudge151
    Sean
    Connecticut
    on a side note whats the difference brtween getting the rear tsb vs a 1" AAL (if they even make them? would the AAL be stronger or the new leaf pack
  9. May 18, 2011 at 8:08 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Just a note (I have posted this many times before) for new TW members...
    My 2005 DC bottomed out when I had rear seat passengers or a load in the bed over any bump. I reported this to my dealer, but all I got was that the ride was softer because most prefer that over using the truck as a truck... no TSB mention (or was I aware of... my pre-TW days). I solved the problem myself with Ride Rite Air Bags and Bilstein 5100s in back. That was an excellent solution.
    My 2010 DC (built in Baja) also has a 3 leaf rear spring pak... However, it does NOT bottom out under the same (or any) conditions, so far. So, at least on my new truck the springs are better... I kept my air bags off the '05 in case I would need them on the '10... but not yet... 25,000 miles on my '10!
    I am curious as to why they still have so many of the older model springs and are still using them when they obviously have made stiffer springs?
    Here is the good 2010 left side spring number... note the -K that others with bad springs don't seem to have?:
  10. May 18, 2011 at 8:21 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    If you read through the many threads on this subject, you will see that over 99% are happy they had the tsb done. I think I've only seen two or three comments about the ride being too stiff and not happy they had the tsb done.
    I had my truck done and I am so happy with the results. The ride is much better. Don't have the body roll while turning corners and she rides 1000x better when loaded.
  11. May 18, 2011 at 10:27 AM
    Toymaker
    Toymaker Well-Known Member
    DC
    2013 Tundra RCSB 4x4 TRD OR, Black
    I had the TSB springs put on mine too.
    They made it a little stiffer and added about an inch or so in height, but it rides much better, more like a truck. The truck was too soft in the rear with the original springs and whenever I carried stuff in the bed it would sag noticably.
    I've also installed SuperSprings. One of the best investments I've made and definitely worth it for someone who actually uses their truck to haul things.
  12. May 18, 2011 at 10:33 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    I'm EXTREMELY happy w/ my new TSB. Tiny bit stiffer ride, but 1000 times better than the grandma-car ride of the previous springs. Just finished a 4k+ road trip, and it was smoooooooth. Rides much better than my girlfriend's Honda Accord, and having my 500lb bike in the back doesn't make it sag... as much. Get it done - you'll be fine.
  13. May 18, 2011 at 1:08 PM
    worldtec
    El Paso
    Stock for now....
    Yeah the dealer just ordered the parts so hopefully next week i will get it done and give everyone an update. thanks for you comments. God Bless.....
  14. May 18, 2011 at 9:31 PM
    Tarheelz2350
    Tarheelz2350 Well-Known Member
    Jon
    Dallas, NC
    10 MGM 4x4 TRD O/R DC
    Bilstein 5100's F/R, Tin Snip mud flap mod, Partial Debadge, Rear Diff Breather Mod, Rear Spring TSB, 265/75/16 Cooper Discoverer AT3's, Devil Horn's courtesy of Andres
    Getting mine done in the morning. Then I'm going to a few good rough roads and trails and see what happens. Will let you know. Hoping the shocks get replaced like the asst. service manager said. If they don't, I still get the new leaf packs which is all I wanted anyway. Then I'll get me a set of 5100's.
  15. May 19, 2011 at 12:07 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    The shock replacement was only on the non TRD models (they put trd shocks on them).
    I think they stopped the shock replacement in '10.
  16. May 19, 2011 at 12:26 PM
    DSTaco
    DSTaco Member
    Whittier CA
    '09 Dbl Cab TRD Sport White
    Leer Cover
    I'm also going to get my TSB next week, 09 double cab TRD Sport. I noticed that the ride would sag/bottom out when I would load my dirtbikes, cooler, etc. to go riding. We also have a toneau cover when the bikes are not in, it's pretty heavy. Even my DJ gear loaded would cause the stock springs to be too soft/bottom out. I like the smooth ride when not loaded but I'm willing to take a chance that the TSB springs are not overly stiff:cool:, I'll keep you all posted.
  17. May 19, 2011 at 1:32 PM
    Tarheelz2350
    Jon
    Dallas, NC
    Got the TSB done. It's definitely a stiffer ride. But it's a truck not a sedan. No new shocks though. Didn't think I would get them because the TSB didn't call for it. Damn asst. service manager had my hopes up. Now to get some 5100's when the OE Billies go bad. Handles off road a lot better also. IMHO, get it done even if you think you don't need it.
  18. May 19, 2011 at 7:06 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    I have a 2010 DC LB Sport prerunner with the TSB. Prior to the TSB it would hit the bump stops somewhat with a 700 LB load and a lot with a 1000 LB load. It does not bottom out at all with the 1000 LB load and handles the load MUCH better. Empty, I could not tell a difference with the empty ride before or after the TSB. Since they don't replace the shocks on the sport when you get the TSB, there is not much difference in the ride. If you have a model that does get new shocks, you will notice a stiffer ride.
  19. May 20, 2011 at 8:18 AM
    worldtec
    El Paso
    Stock for now....
    I have the appointment for monday see what happens......:D
  20. May 20, 2011 at 9:20 AM
    KingMoo
    KingMoo Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    my rear end squeaks after 1000 miles. Any chance this TSB upgrade will fix that?
