TSB - Rear Spring or new AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NLF, Jan 6, 2011.
  1. Jan 6, 2011 at 11:11 AM
    NLF
    NLF [OP] Well-Known Member
    Levi
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    OME 884 & Bilstein 5100s @ 0, TSB Rear w/5100s, 20x8 Mamba M2 275/55/20 Geolander, Access Cover
    Would I be happier with an aftermarket AAL or will the TSB ride as good?
  2. Jan 6, 2011 at 11:14 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The TSB will only give you 1" in the rear once it settles, i personally like the ride more once i got my TSB leafs done.
  3. Jan 6, 2011 at 12:01 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Both will give you a stiffer ride than stock.
    What exactly do you mean by "riding good"?
  4. Jan 6, 2011 at 12:16 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I suggest both if you're actually gonna do some towing or loading the bed for things.
  5. Jan 6, 2011 at 1:30 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    I have a non tsb 2007 access cab. It would bottom out with no weight in it going over every bump. We put a ToyTec AAL on it, and a set of 5100's all around to solve the problem. Very happy with the ride now, the fronts gave it exactly 2.5 inches, and the back should have been 2 inches. but even now with weight on it I am well over 3+ inches of lift. If you can get the TSB done under warranty, I would do that first, and then if you feel the need you can do the AAL later.
  6. Jan 6, 2011 at 1:34 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    the TSB is free, if you need an AAL after that do it, or get new leaf packs
  7. Jan 6, 2011 at 1:35 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines front,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights ,Truxedo Tri Fold bed cover ,
    :thumbsup:
  8. Jan 6, 2011 at 1:38 PM
    Falcon86
    Falcon86 Well-Known Member
    Virginia Beachshire
    Bone-stock
    I just got the TSB done a couple days ago. I'm in the "deciding" period as far as what else I'm going to do with the suspension. I love the ride it has now, more "truck-like"/stiff. Doesn't feel like a 1978 Cadillac anymore after I go over a bump.
    It has plenty of height right now, raised by almost 1.5", will probably settle at 1". At that point I think I'm going to throw in 5100's up front at 1.75" and call it a day.
  9. Jan 6, 2011 at 2:17 PM
    lynyrd3
    Bill
    I did the same thing and had to add the 1 1/2 AAL in the rear ,the front was an inch higher than the rear .:annoyed:
  10. Jan 6, 2011 at 3:12 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    TSB and billys at .85 seems to work perfect
  11. Jan 6, 2011 at 3:16 PM
    pudge151
    Sean
    Connecticut
    i agree:)
  12. Jan 6, 2011 at 3:59 PM
    michaelg589
    michaelg589 Well-Known Member
    Free if you have a warranty still. My 07 did not have anymore bumper-to-bumper warranty when I bought it, nor was I aware of the TSB. So, In my case I had no realistic choice other than to install an AAL. So I did, and so far I'm happy. All I've done is added the leaf. No aftermarket shocks or anything. I HAVE had it bottom out with the added leaf, but its harder to do now. I have a double cab btw.
