TSB rear suspension vs Stock Suspension
Discussion in '4 Cylinder' started by glennleno1966, Feb 21, 2010.
  1. Feb 21, 2010 at 11:12 AM
    glennleno1966
    glennleno1966 [OP] Member
    What do you guys think is better the stock suspension that came on you r truck or the tsb suspension for those of you who have had it done also how much different is the ride and how does it handle weight and what is the new ride height since i have been thinking about having it done tell me what you think Thanks.
  2. Feb 22, 2010 at 3:49 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Wouldn't mind seeing 4cyl truck responses. We are lighter, may handle different?
  3. Feb 22, 2010 at 3:55 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    My truck seems perfect with the stock suspension, however, I've never driven one with the TSB suspension to compare the two. Most of the owners on this forum will suggest you get it done and they may be right.
  4. Feb 27, 2010 at 11:15 PM
    Schully
    Schully Well-Known Member
    Aaron
    Austin
    Black 09 2.7 AC 4x4
    I drive a 2.7 AC. Having said that, I had the rear TSB done a mont ago and I can hardly tell the difference as far as the ride is concerned. However, it did increase my rake by around an inch. Get it done! It aint gonna hurt :thumbsup:
    Hope this helps.
  5. Feb 28, 2010 at 2:09 AM
    DIEGO
    DIEGO Member
    california
    o8 taco dbl cab 4x4 off road package
    Just get it done if you can. You won't regret it.
  6. Feb 28, 2010 at 4:40 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The TSB handles better, supports a scoop of mulch easily... not as 'cushy cushy' as the stock suspension. It's a truck...it's not supposed to ride cushy cushy.
    After settling, about 1" rake and I like it that way.
  7. Mar 10, 2010 at 5:02 PM
    Mellow
    Mellow Well-Known Member
    Dallas, TX
    08 Ext Cab SR5 4-Cyl Prerunner
    I just had my '08 AC Prerunner done.
    Before dropping it off, I stood on the rear bumper and bounced up and down... lots of movement.. the whole truck would roll and sway a little...
    Did the same thing when I got it back and it moves once then it's solid, no bouncing.
    The ride is firmer by just a bit.... it's actually hard to tell the difference or if there is any... but, it must be there.
