TSB Spring pack sagging after 4 years
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattN03, Jul 23, 2013.
  1. Jul 23, 2013 at 9:54 AM
    MattN03
    MattN03 [OP] Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I've noticed over a period of time my 4 leaf pack TSB springs have gotten to the point of sagging so the truck sets nearly level. I carry zero weight in the bed normally, but do tow about 3200-4000 lbs (16' trailer + SXS + ATV) about 1-2 times per month. Has anyone else noticed the TSB spring leveling out over a period of time? I had the TSB performed about 4 years ago.
  2. Jul 23, 2013 at 9:55 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes , they suck
  3. Jul 23, 2013 at 9:58 AM
    MattN03
    Bluegrass State
    Guess it's fairly common because that response took 1 minute?! lol
    What is everyone doing as a fix? I don't really want a "lift", but at some point I might have to look at options.
  4. Jul 23, 2013 at 10:00 AM
    OZ-T
    Peter North
    British Columbia
  5. Jul 23, 2013 at 10:00 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Holy crap! Yours lasted 4 years????? I had the TSB done about a year and a half ago and I just had to replace them with All-Pro leafs because the TSB leafs were completely flat! I could jump on the back bumper and bounce the bed off the bump stops. The warranty offices refused to honor a second leaf pack lol...
    and I quote..."Toyota is aware of the defective leaf packs in the Tacoma" that was the reason they refused to warranty a second pack. My dealer just shook his head, he was about to throw another pack on for me...but called the warranty office up on the spot just in case...
  6. Jul 23, 2013 at 10:01 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Mine were flat after a year. I installed Dakars and will never look back
  7. Jul 23, 2013 at 10:04 AM
    MattN03
    Bluegrass State
    What kind of price am I looking at with these other spring packs? I'd do the install myself.
  8. Jul 23, 2013 at 10:14 AM
    OZ-T
    Peter North
    British Columbia
    Did you not see the link I posted ?
  9. Jul 23, 2013 at 10:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm surprised yours lasted 4 years! I got about a year on mine before they were flat again. You could always go with air bags, they are a good option for people who tow and haul but want to remain at stock height.
  10. Jul 23, 2013 at 10:31 AM
    MattN03
    Bluegrass State
    I did, but thought there might be preferred vendors on TW offering discounts and such.
  11. Jul 23, 2013 at 10:32 AM
    Pugga
    Massachusetts
    Wheelers is one of those preferred TW vendors. I'm not sure if they offer a TW discount but they are great people to do business with.
  12. Jul 23, 2013 at 1:34 PM
    kb2tha
    kb2tha Well-Known Member
    Delaware County, NYS
    08 SR5 TRD OffRoad
    Scangauge
    For about $300 plus some time to install, I would suggest the Firestone Ride Rite air bags. Sounds like it will fix your spring issue. :)
  13. Jul 23, 2013 at 1:35 PM
    VolcomTacoma
    Jeff
    NorCal
    ^That's a bandaid. Not a fix.
  14. Jul 23, 2013 at 1:42 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    also, pain in the rear if you tow and haul a lot
  15. Jul 23, 2013 at 1:43 PM
    Pugga
    Massachusetts
    How do you figure? It takes the leaf springs out of the equation, the air bags essentially become the load bearing element of the truck's suspension.
  16. Jul 23, 2013 at 2:19 PM
    VolcomTacoma
    Jeff
    NorCal
    But you're still stuck with shitty leafs. If an airbag goes out while he's towing...he's gonna be kinda screwed. would rather have both, if I towed often. that way if either one fails, you've got a backup. That's essentially the same as putting an AAL into a flat leaf pack to give lift. You're not fixing the issue, you're trying to work around it..which in this case...will only hurt in the long term.
  17. Jul 23, 2013 at 2:37 PM
    MattN03
    Bluegrass State
    Yea, I'm not really interested in the hassle of airbags. The truck still tows as good as it ever has, I'm just wondering if I'll have to replace the packs eventually since I only have 59k miles and hope to keep it a lot longer.
  18. Jul 23, 2013 at 2:44 PM
    VolcomTacoma
    Jeff
    NorCal
    Thing is OP, if your leafs are flat/dead...you're towing off your bumpstops, which is never good.
  19. Jul 23, 2013 at 2:50 PM
    OZ-T
    Peter North
    British Columbia
    X2
  20. Jul 23, 2013 at 5:56 PM
    stump jumper
    Bill
    Texas
    you have to put air in them, correct?
