TSB spring vs. AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glwood6, Dec 24, 2010.
  1. Dec 24, 2010 at 12:50 PM
    glwood6
    glwood6 [OP] Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    Would they accomplish the same thing as far as ride and height?
  2. Dec 24, 2010 at 12:51 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I would say so
  3. Dec 24, 2010 at 3:46 PM
    2K6 Taco
    2K6 Taco Well-Known Member
    Philly
    06 TRD Sport D-Cab LG Bed
    Yes but the tsb springs were meant to improve payload. AAL is only for height and possibly ride comfort. The tsb has all the above; payload,height and ride.
  4. Dec 24, 2010 at 3:47 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    What is the rear TSB? Why does everyone talk about it and the dealer? I have a 2010 trd sport I just got in august, does mine have the tsb already done? or should i ask them to do it at my 5k service
  5. Dec 24, 2010 at 3:56 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Not height... the TSB springs settle to about 1" of lift.
    Most AAL's are 1.5" or 2".
  6. Dec 24, 2010 at 3:57 PM
    KPT
    09 Prerunner
    Search leaf spring TSB and you'll find more than you need.
    If you have 4 leafs in the back, you have TSB already preformed. If you have 3, you do not have the TSB performed. If you bought it new, then you definitely don't have the TSB.
  7. Dec 24, 2010 at 4:00 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2.
    you would think Toyota would already have the TSB done on the newer trucks.
  8. Dec 24, 2010 at 4:00 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Can I get it done at the dealer at m 5k service or somethin?
  9. Dec 24, 2010 at 4:01 PM
    KPT
    09 Prerunner
    Probably....like I said do some research to see if you really want it.
  10. Dec 24, 2010 at 4:03 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    Yes you can. I dont know where in Oregon you are. But I had mine done Gladstone Toyota in Milwaukie when I had 3K on my truck.
  11. Dec 24, 2010 at 4:04 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You could, just call the dealer and tell them the ride is harsh. My dealership didn't give me much objection to getting it done.
  12. Dec 24, 2010 at 6:27 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    I just got done doing the Toytec Non - TSB AAL's a couple weeks ago, along with 5100's all around. I set the fronts on 2.5" and the AAL was supposed to add only 2" to the rear. My truck has an A.R.E. contractor cap,a couple 24 foot fiberglass ladder, plus a few hundred pounds of equipment. Before the AAL I had 34" to the inside of the fender flare. After the AAL we had right at 38" giving us a 4 inch lift. In order to try and get it to settle, there is 200 pounds of sandbags in the back also. Not sure if this is normal, and not really a big deal as we haul alot and can use the extra support,but 4 inches of lift might be an issue to someone expecting just 2 inches out of a set of AAL's.
  13. Dec 24, 2010 at 8:16 PM
    KPT
    09 Prerunner
    That's definitely not normal. Could you take a picture of the leaf setup so we can take a look?
  14. Dec 24, 2010 at 11:32 PM
    glwood6
    Gary
    Albuquerque, NM
    The reason I asked is I would like eventually going to a 265/75/17 tire on the next replacement, and would also like to do some 5100s set at .85 to get a little more room up front. That would mean doing something on the back for a little more height, but I don't want to go crazy, and would like the ride to stay within reason. I also don't know if they would do the TSB on an '05 at this point. I've never bottomed out on my springs, loaded or otherwise.
  15. Dec 25, 2010 at 8:37 AM
    romafern
    romafern Well-Known Member
    Rob
    Olympia, WA
    stock and very pissed about the issues
    Machine gun mount. Would love to blow the shit out of it since it has nothing but issues. QA at Toyota USA is shit. Start making them in Japan for Christ's Sake!
    :popcorn:enrolled
