TSB Spring Vs. Non-TSB Spring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EGoldie, Oct 28, 2014.
  1. Oct 28, 2014 at 11:50 AM
    EGoldie
    EGoldie [OP] Some Miles Under My Belt
    Evan
    Austin, TX
    08 DCSB TRD Sport 4x4
    OME 885/Dakars, 285/70/17 Toyo AT2, LR UCAs
    Hey guys,
    Picked up a 2008 DCSB Sport 4x4 a few weeks ago and have been in the process to getting all the fluids changed, driveline greased, etc. Just getting it up to speed so I know where it sits as far as maintenance goes.
    The truck has some sort of spacer lift on the front end and what appears to be factory rear leaf pack in the rear. I'm trying to determine if the rear leafs I have are the TSB version or not. I have been under the assumption that since the truck has 285/70/17s installed that they wouldn't fit under a non-TSB leaf pack so that these must be the improved TSBs.
    Attached is a picture of what's installed on my truck. If someone could help me confirm which one I've got, that'd be great. Would help me decide if I should get Dakars or a 3-Leaf Progressive AAL with my OME 885s.
    Thanks!
  2. Oct 28, 2014 at 11:53 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    TSB has 4 leaves, which is what you have there. So either that is TSB or someone added a leaf.
  3. Oct 28, 2014 at 12:02 PM
    cgs2k2
    cgs2k2 old man
    Looks like somebody added a leaf.
  4. Oct 28, 2014 at 12:43 PM
    EGoldie
    Evan
    Austin, TX
    Hmmm. I hadn't thought about the possibility of someone already adding a leaf. Are we thinking it is the very bottom leaf? The end profile is different than the others as it is rounded where the rest are square.
  5. Oct 28, 2014 at 1:09 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats definietly a standard 2+1 leaf pack with an AAL.... toyota 3+1 leaf packs do not have the 3rd leaf down so short.
  6. Oct 28, 2014 at 1:42 PM
    EGoldie
    Evan
    Austin, TX
    Thanks for the feedback, guys!
    It's been about 10-12 years since I've owned a vehicle with leaf springs (I design suspension and performance parts for the turbocharged tuner world) so it'll take some time for me to learn everything there is to know/dump too much money into this truck. No worries, though. It always happens.
    Looks like it's time to order Dakars.
