TSB Timing Cover Leak Not Covered Under Warranty
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kev_SLC, Jul 27, 2015.
  1. Jul 27, 2015 at 2:12 PM
    kev_SLC
    kev_SLC [OP] New Member
    Kevin
    2006 Toyota
    Hi everyone,
    I purchased an 06 Tacoma back in March with 80k miles on itand took it in for service the other day. I was told I have a leak on the timing cover and that it was going to cost $2100 dollars to fix this. I had purchased an extended warranty through the Toyota dealer and they are refusing to fix the issue because it is a seal and gasket which my warranty does not apparently cover. The Toyota dealer is using a 3rd party warranty company.
    Any suggestions on moving forward at this point in time? The dealer said it was fine to leave as long as I watch the oil level but I would rather have this fixed.
    I have also seen varying prices from $1500 to the highest being mine at $2100.
    Any thoughts welcome, and thank you!
  2. Jul 27, 2015 at 3:31 PM
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Get a refund on the obviously useless warranty and have them repair the leaky seals and gaskets. Seriously, leaky gaskets and seals can have a cascading effect on the lifespan of rubber and plastic components under the hood of your truck. What happens when that leaky timing chain cover starts to drip onto your lower radiator hose? Well, it starts to swell, and when that happens, not good... CV boots with longterm exposure to leaky engines, not good. Toyotas are known for their reliability but only you can extend that lifespan by making good choices.
  3. Jul 27, 2015 at 3:49 PM
    kev_SLC
    Kevin
    2006 Toyota
    My thoughts exactly, I would rather just take care of this and be done with it. Already in the process of cancelling the warranty. Since they have to drop most of the front end to complete this they want to flush the radiator and also bleed the brakes. Looking like $2400 after everything.
  4. Jul 27, 2015 at 4:14 PM
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    The radiator flush and brake bleed are a preventative maintenance issue.
  5. Jul 27, 2015 at 4:14 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    You don't mention what engine you have, but if you have the 2.7L, you might want to have a look at this thread.
  6. Jul 27, 2015 at 5:09 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Never had a extended warranty that was any good. There all mostly BS. Good luck OP.
  7. Jul 28, 2015 at 3:43 PM
    kev_SLC
    Kevin
    2006 Toyota
    Ah, forgot to mention it's a 4.0 V6.
    I had an 07 Tacoma before with a MasterTech warranty that I was actually pretty happy with. This new warranty is a much lower quality sadly. Looks like I'm fitting the bill for the fix despite an extended warranty. Live and learn.
    Thanks for all the replies!
