TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlalien, Apr 29, 2011.
  1. Apr 29, 2011 at 7:31 PM
    dlalien
    dlalien [OP] Well-Known Member
    Jose
    North Hollywood CA
    08 TRD Sport DCLB 4WD, Tow package
    ABOUT HOW MUTCH LIFT DO YOU GET AFTER GETTING THE REAR TSB DONE
  2. Apr 29, 2011 at 7:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    ABOUT .75" AFTER IT SETTLES
  3. Apr 29, 2011 at 7:32 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    LOUD NOISES
  4. Apr 29, 2011 at 7:35 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I AGREE WITH CHRIS
  5. Apr 29, 2011 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    THANK YOU OZ
  6. Apr 29, 2011 at 7:39 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I HAD THE TSB DONE AND PUT BILLIE 5100'S UP FRONT. THEN 265/70/17. IT LOOKS STOCK. SO I AGREE WITH CHRIS. ABOUT .75"
  7. Apr 29, 2011 at 7:40 PM
    OZ-T
    Peter North
    British Columbia
    YOU'RE WELCOME CHRIS
  8. Apr 29, 2011 at 7:41 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    THAT'S EXACTLY WHAT I WANT TO DO. YOU WOULDN'T HAPPEN TO HAVE ANY PICS WOULD YOU?
  9. Apr 29, 2011 at 7:41 PM
    OZ-T
    Peter North
    British Columbia
    MINE WAS STOCK WITH THE 4 LEAF PACK ALREADY INSTALLED , THEN I RIPPED THEM OUT AND PUT IN DAKARS
  10. Apr 29, 2011 at 7:42 PM
    pudge151
    Sean
    Connecticut
    VERY NICE. I WOULD LOVE A NEW STRONGER LEAF PACK BUT CANT JUSTIFY THE COST
  11. Apr 29, 2011 at 7:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I HAVE NOTHING MORE TO ADD OTHER THAN I WANT TO TYPE IN CAPS
  12. Apr 29, 2011 at 7:44 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    GO BIG OR GO HOME
  13. Apr 29, 2011 at 7:44 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    THAT IS ALL
  14. Apr 29, 2011 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    HA
  15. Apr 29, 2011 at 8:41 PM
    dlalien
    Jose
    North Hollywood CA
    thanks so if i get 5100s i would set them at .75 to level it out
  16. Apr 29, 2011 at 8:42 PM
    OZ-T
    Peter North
    British Columbia
    1.75
  17. Apr 29, 2011 at 8:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This ^^^
  18. Apr 29, 2011 at 8:45 PM
    OZ-T
    Peter North
    British Columbia
    20
  19. Apr 29, 2011 at 10:52 PM
    dlalien
    Jose
    North Hollywood CA
    how mutch of of a lift do i need to go bigger then 265/70/r17
  20. Apr 30, 2011 at 7:09 AM
    pudge151
    Sean
    Connecticut
    if you do this the back will will be higher, pretty much like the stock rake, the nice part is when you load the bed the headlights wont be shining high
    if you do this it will look level but will probably be a little nose high, especially when you load the bed
    no lift required, but unless you go 3" and do some trimming thats the biggest size tires you can fit
