Tsb?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chromeoverbrass, Feb 7, 2009.
  1. Feb 7, 2009 at 12:19 PM
    chromeoverbrass
    chromeoverbrass [OP] New Member
    Virginia
    07 TRD SR5 Doublecab
    Been reading a lot about TSB but don't really understand it. Is there some kind of recall that I should have done before I put a 3 inch lift on my truck? Or is this something that will enhance what I am planning to do? Can I get some scoop? I plan on putting a Bilstein 5100 package and either AAL's or 1 inch blocks in the back.
  2. Feb 7, 2009 at 12:20 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    my knowledge of TSBs is that they are not saftey issues, therefore no technically recalls
  3. Feb 7, 2009 at 12:21 PM
    HighPlains
    HighPlains Well-Known Member
  4. Feb 7, 2009 at 6:37 PM
    chromeoverbrass
    Virginia
    Thanks High Plains for the insight. I was beginning to wonder what I was missing out on. My Tacoma isn't giving me a harsh ride. It just rides like a very little truck on the ars end! If you are going to go with a lift and an AAL is this procedure worth the time at the dealership?
  5. Feb 7, 2009 at 6:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Toytec offers a lift for you to install if you have the TSB done, however just going with an AAL will come out all the same.
