Tsb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fire544, Mar 21, 2009.
  1. Mar 21, 2009 at 12:52 PM
    fire544
    fire544 [OP] Anytime, Anyplace....
    Called local dealer yesterday about the Harsh Ride TSB. Droping the yota off Monday during lunch for and evaluation? He said that he had to check and make sure that my truck was eligible for the TSB? Has anyone else ran into this from a dealer?
  2. Mar 21, 2009 at 1:06 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    its extremely common. If you do a search for rear suspension TSB you will get tons of results.....
  3. Mar 21, 2009 at 1:46 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    Sparks, NV
    2011 TX TRD 4x4 DC
    OME Lift W/886 Coils/LR UCA's/BAMF LCA Skids/Daker Leaf Packs Fab Fours front bumper/Warn M8000 winch Relentless Fab Rear Bumper/Tailgate Skin/Front skid plate DB Fab Grille Insert with Baja Designs Cube LED's 285/75/16 Nitto Terra Grapplers N-Fab Steps Compustar remote start UWS low pro box Carhartt Seat Covers/Door Inserts/Console Cover OEM Bed Mat Bulletproof Fab Engine Tray/Lower Grille Insert .50 Cal Antenna/Valve Stem Covers Custom Fab Console Lock Box Custom Shift Knob Dash Mat Window Tint Rugged Ridge Floor Mats Blacked Out Emblems Color Matched Grill Surround G-Tek Door Sill Protectors Wheelskins Steering Wheel Cover EGR In Channel Vent Visors FJ emblem on the tailgate Northstar battery TRD battery tie down Illuminated 4X4 switch Bed stiffeners/Bed Extender with custom mounts Redline hood struts Relocated rear diff breather Console Molle Boards Lot's of patches!
    Your response to the dealer should be as follows: "Well I believe you have my vin # but if not here it is. That should provide you all the information you need for qualification. As far as anything else such as putting weight in the bed or any of that BS I have a copy of the TSB and it clearly states that if the customer makes the complaint then the work is to be done at the expence of Toyota at any authorized dealer. Then ask if you need to contact Toyota or if he has a time that you can drop it off!"
  4. Mar 21, 2009 at 1:51 PM
    wcm608
    wcm608 Well-Known Member
    Pittsburgh, Pa
    08 DC LB 4x4 SR5 Impulse Red
    That's exactly what my dealer told me. Dropped it off and 3 hours later I
    received the call saying parts were ordered. They kept it overnight and was done by noon the next day. They told me he had to look at it and was not allowed to just order parts without seeing it.
  5. Mar 21, 2009 at 1:54 PM
    wcm608
    Pittsburgh, Pa
    By the way, I stopped in to make the initial appt. and had a copy of the TSB in hand. They wanted to know where I got it.
  6. Mar 21, 2009 at 3:15 PM
    fire544
    Does anyone have a copy of the TSB(2008), so I can have it for back-up ammunition?
  7. Mar 21, 2009 at 3:18 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  8. Mar 21, 2009 at 4:30 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Ok this is driving me crazy. I hate all these abbreviations. So what does TSB stand for and why is it such a big deal. I tried reading the posted link and I assume that it means toyota safety bulletin. What does this have to do with suspension? If you have tampered with the suspension (putting on a leveling kit) does it still need to be done?
  9. Mar 21, 2009 at 4:39 PM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Ditto. I'm waiting for the call that my parts are in. Should be within the next week.
  10. Mar 21, 2009 at 4:40 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Technical Service Bulletin. It's not a recall so it's not guaranteed that they'll replace it. It's a replacement of the stock shocks with TRD shocks (if your truck is non-TRD Access or Doublecab) and the rear leaf springs. If your truck is a TRD, they only replace the stock leaf springs: 3 pack to a 4 pack. The stock trucks are known for bottoming out in the back (hits the bump stops). Mine would do it unladen over a curb. It doesn't need to be done unless you're bottoming out. On mine it firmed up the rear and raised it about 1".
  11. Mar 21, 2009 at 6:47 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Ok gotcha, thanks. Its taking me a while to figure out a lot of these abreviations. I havent really noticed it bottoming out but I havent really paid attention either.
  12. Mar 21, 2009 at 7:19 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    i had the tsb done. trust me it rides better with the 4 leaf and i can load more shit in the bed without it saggin
  13. Mar 24, 2009 at 4:06 PM
    fire544
    OK...dealer ordered parts, will call when they come in. Hopefully it happens this week, so I can get those billies installed! Thnx for all the help guys...thinking about 285/70, will they rub?
  14. Mar 24, 2009 at 4:57 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    How much of a lift are you doing?
  15. Mar 24, 2009 at 5:11 PM
    fire544
    Just the TSB, and 5100's all the way around, front set at 2.5
  16. Mar 24, 2009 at 5:23 PM
    Joe B
    Joe B Well-Known Member
    Just dropped my '09 off with the printed TSB that had one of the 5 digit sequences in my Vin# and the older part # pieces,not the TSB leaf part #s.
    We'll find out sometime tomorrow morning if the dealer will do the TSB and order the parts.
  17. Mar 25, 2009 at 6:10 PM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Got my TSB completed today- wow what a difference, rides so much better and feels much more stable. The tech told me they also replaced shocks and adjusted the alignment. I'm happy! :cheers:
