Tsb--?
Discussion in '1st Gen. Tacomas (1995-2004)' started by derekp, Jan 20, 2010.
  1. Jan 20, 2010 at 3:31 PM
    derekp
    derekp [OP] giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
  2. Jan 20, 2010 at 3:37 PM
    Brunes
    Brunes abides.
    Rotorhead
    Nope- It does not. The TSB usually defines the period of coverage. The rear leaf spring TSB only covers trucks under the factory 3/36 warranty.
    The TSB only gives the Toyota techs solutions to hard to diagnose/repair problems. They don't really mean anything other than that.
  3. Jan 20, 2010 at 3:43 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    so as I've never dealt with a tsb before, how does this work? I print this page, and bring it to toyota and they fix something?
  4. Jan 20, 2010 at 3:51 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    As I understand it, when there is a known problem Toyota comes out with a bulletin for the service department to go by. If your under warranty and are experiencing a certain issue, they will check and perform the tsb if it's related to your problem and they can prove that you do indeed need the service. You are entitled to the service as long as your model, year, and vin# are called out in the tsb. Getting it done is a different story sometimes as some dealerships act like they have never heard of a tsb. Try another dealership if you can't get satisfaction.
  5. Jan 21, 2010 at 4:35 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
  6. Jan 21, 2010 at 4:41 PM
    Brunes
    Brunes abides.
    Rotorhead
  7. Jan 21, 2010 at 4:58 PM
    kevhogaz
    SR5 PreRunner
