Tsunami wiring kit tube is ringing
Discussion in 'Audio & Video' started by rondog, Apr 14, 2012.
  1. Apr 14, 2012 at 3:26 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    I had my battery disconnected for about an hour and now the tsunami wiring kit tube thing has this kinda quiet high pitched ringing tone coming from it. It does it even with the keys outa the ignition. Anyone know what that means?
  2. Apr 14, 2012 at 3:36 PM
    rondog
    Ronnie
    Escondido/San Diego
    The tube thing is the capacitor
  3. Apr 14, 2012 at 3:42 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I have a tsunami capacitor in my truck and it will ring like that if the volts are too low. You will have to let the capacitor charge up to I think above 9 volts for it to stop ringing
  4. Apr 14, 2012 at 3:43 PM
    rondog
    Ronnie
    Escondido/San Diego
  5. Apr 14, 2012 at 4:04 PM
    tacobell007
    Drew
    Western MA
    Have you tried getting your alternator tested or testing it yourself? Or the battery? My friend's mercury marauder has an idle and charging problem because of the under drive pulley system on it
  6. Apr 14, 2012 at 4:18 PM
    rondog
    Ronnie
    Escondido/San Diego
    How would I test it? I've kinda suspected issues with the alternator because doing simple things like rolling windows down with cause my idle to drop
  7. Apr 14, 2012 at 4:51 PM
    tacobell007
    Drew
    Western MA
    Can either test it by a volt meter or if you wanted to you could take it out of the truck and bring it to autozone or advance auto parts and have them test it. I'm not exactly sure how to test with the volt meter, but you should be able to find out how relatively easily
  8. Apr 14, 2012 at 4:57 PM
    rondog
    Ronnie
    Escondido/San Diego
    my brother in law just said use a volt meter on the battery and if its below 12v or so its probably bad..I have 4 big HIDs, 2 amps and 2 subs so I may have worn it down
  9. Apr 14, 2012 at 10:04 PM
    tacobell007
    Drew
    Western MA
    I think that test is suppose to be used when starting the motor to see about the cranking power under a load. The more stress on the electrical system, the sooner your alternator will start to go and in return will not charge the battery as well as it should
