TSynthetic oil dries out seals?????
Discussion in 'Performance and Tuning' started by lodi781, Apr 8, 2013.
  1. Apr 8, 2013 at 8:49 AM
    lodi781
    lodi781 [OP] Alexander Supertramp
    shelton CT
    '16 4runner trail
    ARB by-51’s, dobinson springs, Gobi Rack, Black Oak single row LED roof bar
    ...My buddy told me that if ive been useing conventional oil, whether gear or engine, to stick with it because synthetic dries out the seals...is this true?
  2. Apr 8, 2013 at 8:53 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    No.
    Synthetic oil will not damage your seals, not will it cause leaks. If you have an existing leak, synthetic oil MAY make the leak worse.
  3. Apr 8, 2013 at 8:53 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  4. Apr 8, 2013 at 8:53 AM
    JDMcQ
    Beat ya Max!
  5. Apr 8, 2013 at 9:37 AM
    lodi781
    shelton CT
    '16 4runner trail
    Thanks fellas.....I thought that sounded off...My truck just hit 92k and I want to switch to synthetic on the next change.
  6. Apr 8, 2013 at 9:46 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    syn has less additives and doesnt cause swelling of seals...................dino usually DOES, which is why people used to say incorrectly "when I switched to syn, I got leaks"
    truth was, they already had swollen up seals from some of the detergents in dino......thn they used a clean synthetic and it was safer for the seals and caused no swelling.....so the syn just exploited leaks that were already there.
    U should have no leaks on an '08
    besides I ASSUME (maybe wrong) that newer dino oils may cause less swelling than they used to.
    use syn, u will be fine..............Ive NEVER had an issue........I used it on a junkyard engine in my maxima and beat the snot outta it, breaking trans/motor mounts 3 times.............NEVER had an oil leak, and it was an 89, so odds are it was changed with dino before I got it.
  7. Apr 8, 2013 at 9:46 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Sheesh where do people get this stuff, lol.
