TTC ☆ OFFICIAL
Discussion in 'Texas' started by ChadsPride, Mar 28, 2018.
  1. Jan 16, 2019 at 10:37 AM
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
  2. Jan 16, 2019 at 10:38 AM
    mipawlus
    mipawlus #332 Veteran Overland, #159 TTC, #69 in your heart
    Captain Poopypants
    Aggieland
    BROJAHAHAHAHA!!!!
    Rust and dents and squeaks
    If the tax and intrinsic benefits of hiring a "special category veteran" dont sway them.... I doubt any of my other affiliations will lol.
  3. Jan 16, 2019 at 10:40 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Time to Smoke a Brisket by the front doors & start glad handing Folks.
  4. Jan 16, 2019 at 10:42 AM
    Mdbarba
    Mdbarba Member
    Thanks jlusmc, and hi TTC. Looking for a sound upgrade on my 3rd gen, shops and equipment recommendations in dfw area.
  5. Jan 16, 2019 at 10:46 AM
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Your welcome. Hope you find what your after. Regardless tag this page and hang out, lot's of knowledge, help and fun bs in here.
  6. Jan 16, 2019 at 10:47 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Try looking at https://www.cartoys.com/ I have heard good things but never done business with them
  7. Jan 16, 2019 at 10:48 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Heavy on the BS when the crow is flying around
    RobP62, Nopro, ChadsPride[OP] and 3 others like this.
  8. Jan 16, 2019 at 10:51 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    All those kinda places have crazy shop rates
  9. Jan 16, 2019 at 10:51 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
  10. Jan 16, 2019 at 11:11 AM
    Mdbarba
    Mdbarba Member
    Have gotten in trouble doing that in the past. Never messed with audio so it’s one of those that I’ll leave it to someone who has the proper tools and knowledge. Rather spend the install $and not worry about it. just looking for something that works well in the Tacoma not cheap but also not looking to go over the top. I thought getting close to 1k would get something decent but apparently it’s still not enough to get out of the cheap category.
    Good feedback btw I’ll be on here more often.
  11. Jan 16, 2019 at 11:20 AM
    penbergm
    penbergm 86T4R
    Leander
    1986 4Runner 3.4l heart transplant
    Monstalined (Killer Beej & Jungle Love), 35's, 4.88's detriot rear, aussie front, tactical armor rear swingout, TG front w/ Smittybilt 9.5k winch.
    I'll be your mechanic and charge you half price. $550! :spending:
  12. Jan 16, 2019 at 11:29 AM
    penbergm
    penbergm 86T4R
    Leander
    This is doable but it's more than just banging a screwdriver in the holes. Read all of this and see pics at below linked site before attempting. There are 4 outer lock tabs in those holes. When you look in the hole it looks like 2 thin barb ends sticking up. One barb is metal. Put the screwdriver BETWEEN the barbs and twist, then pry against the metal one. It's the one you're trying to unlock. You're trying to pry it away from the center of the hole. Now tap the screwdriver with a mallet (I used a pair of pliers ha) til the thick end of the screwdriver blade is between the barbs, and twist and pry again.This may take a few tries. I took the battery out and snipped the tie down holding the wire bundle under the fuse box, as well as the bolts holding the fuse box (after unlocking first 4 locks), to loosen things up enough for the inner fuse box to slide out.... Now the hard part. Splitting the inner fuse box... Along the seam between the left half and the right half of the inner fuse box, there are two tiny slots just big enough to fit a #2 flat head screwdriver tip. Bang it in an inch and pry the handle of the screwdriver in the direction of the windshield to unlock but don't break anything. Make sure you find the right slots it's the THIN ONE. Next to a fatter slot. Just big enough for the tip if a smaller flathead screwdriver. There is a thin ridge of plastic very near the center of the inner fuse box where you can grasp it with a pair of good piers. I used linesmans pliers. Bang on a safe area of the left half while holding the fin (attached to the right half) with the pliers. If you unlocked the inner 2 locks, (these are just plastic locks and no way to see them until apart) it should shift. The left half goes down, the right half goes up. Oh yeah, you have to hold the whole thing up while splitting, so it doesn't lock back into the outer box. It may take more prying, twisting, and banging, than mentioned above. Try not to break anything. Once apart use a long socket ( I used a short socket on a 1/4 to 3/8 adaptor) Break the bolt and then pull off the ratchet, finger spin it out. and careful not to let the bolt fall out of the socket when you get it out. It's very short. One on both sides. 10mm and 8mm. In hindsight, I may have used a dab of grease in the socket to help with not dropping it out while installing and removing, but I managed. This will also work for the 40 amp heater ( blower motor) fusible link in left half, as well as the alternator 140 amp fusible link in the right half of the inner fuse box. There are pics here showing where the 4 outer locks are and the (thin slot next to fat slot) split locks are close to them at each end in the pics. Use the thin slot. http://www.toyota-4runner.org/problems-warranty-issues/25350-changing-fuse-simple-not-2.html
    Bigdaddy4760 and ChadsPride[OP] like this.
  13. Jan 16, 2019 at 11:48 AM
    TEXAS BS
    JB
    Texas
    Now my head hurts.
    Nopro, FastEddy59, T4Rgurl and 4 others like this.
  14. Jan 16, 2019 at 11:50 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Is it Trials or Trails?
  15. Jan 16, 2019 at 11:56 AM
    penbergm
    penbergm 86T4R
    Leander
    I can fix that too. $45
    KENNY, Nopro, RobP62 and 6 others like this.
  16. Jan 16, 2019 at 12:05 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    OK, said slacker is done. Here is your menu - will be delivered ~7:30 by slacker;
    15 Bacon, egg, & cheese
    15 Sausage, egg, & cheese
    10 Potato, egg, & cheese
    10 Chorizo & egg
    I don't think any cookware will be needed, or loose groceries. @GoddardPool , please bring that salsa I left, and those old styro plates.
    BRING a heater!
  17. Jan 16, 2019 at 12:08 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    :bowdown::bowdown::bowdown:
    Nopro and ChadsPride[OP] like this.
  18. Jan 16, 2019 at 12:16 PM
    Pyrotech
    Pyrotech Well-Known Member
    Been planning on a dual battery setup, willing to volunteer my 2019 for testing
    Oldie2007 and Bigdaddy4760 like this.
  19. Jan 16, 2019 at 12:17 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Which one you going with it’s on my mod list. Off grid dual battery system
  20. Jan 16, 2019 at 12:18 PM
    T4Rgurl
    T4Rgurl Well-Known Member
    Christa
    Lago Vista Texas
    2013 4Runner
    Not in dfw but our go to is @Texoma Triple C Chop Shop
