TTC ☆ OFFICIAL
Discussion in 'Texas' started by ChadsPride, Mar 28, 2018.
  1. Jan 25, 2019 at 12:14 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    I had to do something stupid in 4WD so I stopped being mad at the truck so I climbed the wall in front of our house. Featuring why I was stupid for pulling out the front locker #layindownrubber
  2. Jan 25, 2019 at 12:26 PM
    CarmenSanDiego
    CarmenSanDiego Battle Tank
    Kelly
    Dickinson, TX
    2011 MGM 4Runner Limited 4x4
    Bilstein 5100's OME HD Springs Shrockworks Sliders Addicted Offroad Front Bumper Proline 4x4 Rear Bumper CBI skids Black Rhino Armory wheels
    Depending on their process then that could be a reasonable cost. We would probably be on the higher side around 6K+ as we will completely remove all trim and glass so you dont end up with any hard clear lines. A lot of places will just tape and mask off everything instead of removing and you run the risk of having those lines when they peel the tape off. Some cars it's not an issue because the windows are easy to mask and some the fitment is so tight theres not a good way to mask it without removing.
    We can but then it's a 25% up charge on it as a sublet. I would contact Guffeys Glass on Facebook. The owner Otis is a friend of mine and has done glass in my 4runner several times as well as most everyone I know. Tell him I sent you. He will also come to you which is helpful so you don't have to sit somewhere and wait for them.
    Wet sanding if it's just starting and then respraying with clear and then cut and buff afterwards CAN be an option but often when we see these the clear is already too far gone and will start flaking even worse when sanded.
    Paint cost has jumped as better more environmental friendly paints and water based paints were developed and put into place over solvent based as well.
    Sometimes it can be, but fixing the roof and hood on most vehicles stops the issue. Those two panels being exposed to the Texas sun seem to take the worst beating. Sometimes the tops of fenders will as well but normally just roof and hood.
    Some of what you pay for when fixing the panels is also us doing everything in our power to make sure you can't look at the truck and the panel we painted isnt a significantly different color. The paint codes often have several(I've seen up to 14)different variances and so they have to do spray outs to determine which one to go with as well as blend if you have panels that "dead panel" to each other. So if we paint your fender we would usually blend into the door to make sure that the color isn't glaringly different. This is especially important on metallic colors as the new paint may lay down a little differently so you will see variants in the way it refracts light etc. We do our best to make sure once it'sdone you can't really tell we were ever there. I'm sure someone could explain this better than me, but I'm trying. :oops:
  3. Jan 25, 2019 at 12:29 PM
    CarmenSanDiego
    Kelly
    Dickinson, TX
    Excuse the screenshot I didnt feel like digging for a picture. This is where I have mine.
  4. Jan 25, 2019 at 12:34 PM
    CarmenSanDiego
    Kelly
    Dickinson, TX
    @Bigdaddy4760 @Misplaced Nebraskan I have a noob question regarding brisket.
    Theres no way in hell my tiny electric smoker will fit a full brisket but my HEB sells point/flats separately and I don't know the difference in what each one is. I believe the point is the fatty side and the flat is the less fatty side? I prefer the fatty cut but was also wondering if you've cooked one of these and how they came out. Price wise is ridiculous for what they are but size wise seems perfect for just the boyfriend and I.
    Thanks!
    Bigdaddy4760 and Oldie2007 like this.
  5. Jan 25, 2019 at 12:37 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Thank you Patrick, I appreciate you
    Oldie2007 and RobP62 like this.
  6. Jan 25, 2019 at 1:16 PM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    Like I don't know anything about smoking meat?
    You have the description of the pieces right, and it's a matter of what you want the meat for. The point is fantastic for making burnt ends, not so much for eating it by itself sliced. The flat is the opposite of that. What you get at a restaurant, depending on if you tell them you want, lean or fat, will come from a piece of meat that has the flat and point still attached, and your answer determines what end the slices come from.
    My suggestion is to get a bigger smoker...
    Nopro, RobP62 and Oldie2007 like this.
  7. Jan 25, 2019 at 1:16 PM
    lilred95
    lilred95 TTC #014
    Cody
    Leander TX
    95 tacoma 5spd 2.7 4wd "Scarlett" 06 Lexus GX470 "Sexy Lexi" 14 Yz450f 06 ttr230
    need more
    :smokertransformer:
    Oldie2007 and RobP62[QUOTED] like this.
  8. Jan 25, 2019 at 1:17 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Everyone listen up good, here! This is the difference between most all of the steps, well explained. I got lucky because;
    I still had "good" paint under the bad clear. I only needed a little touch up under the clear.
    The guy who did it is a long time friend, with a small shop. But he did virtually all of those little details Kelly mentioned -removed vs. masked, etc.
    And because of the mostly good paint, was not so hard for him to blend to the good.
    Lastly, a pro shop like Kelly's ISN'T going to take those money saving shortcut. I know they offer a true warranty (I've seen it said!)
    Old saw, you get what you pay for. Sometimes, friends can help you get a better deal. Sometimes, spending $6K on a $6K truck isn't worth it. I have a $10K truck, I will keep a long time, will not likely abuse (too much), and have less than $1K into making the body nice. For me, that is worth this small investment.
    CarmenSanDiego[QUOTED] and Nopro like this.
  9. Jan 25, 2019 at 1:36 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I thought I read this was taught in pre-school in Texas? :D
    Nopro and Oldie2007 like this.
  10. Jan 25, 2019 at 1:54 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Probably was. Up "there", BBQ mean you are grilling hot dogs and hamburgers. Grilling steak meant grilling steak.....
    No kidding, when we took our son up to beautiful Hoboken, to start at Stevens Institute, BBQ on the yard for the welcome dinner was hamburgs and dogs....
  11. Jan 25, 2019 at 2:02 PM
    Oldie2007
    Kurt
    Lockhart, TX
    :yes:
    I have a 4 burner gas for general grilling, and a 22" Weber I mostly use for indirect smoking, cause it's so convenient!
    Christmas in process;
    Christmas coming in! It's fully butter injected, herb crusted, crispy skinned juicy wonderment!
    RobP62 and CarmenSanDiego like this.
  12. Jan 25, 2019 at 2:52 PM
    CarmenSanDiego
    Kelly
    Dickinson, TX
    My apologies!
    Honestly I like brisket a lot of different ways but when I want just sliced brisket with sides I prefer a fatty cut. I feel like a flat might be better for chopped beef as it wouldn't be as fatty/greasy when mixed with some good sauce.
    jmdaniel[QUOTED], Nopro and Oldie2007 like this.
  13. Jan 25, 2019 at 3:02 PM
    Oldie2007
    Kurt
    Lockhart, TX
    You could do a good smoked brisket on even a small "Smokey Joe" Weber. Get a big brisket (geez they have gotten expensive), probably quarter it. (Freeze the rest)
    You put some charcoal on two sides, a drip pan that fits between. Soak some wood chips (HEB has little bags for cheap). Drink some beer, throw some chips on every 1/2 hour, add some new coal once an hour, and three or so hours later..... yum time.
    Cutting samples is allowed after 2 hours is allowed.
    What you rub or prep it with totally up to you, but avoid salty rubs.
  14. Jan 25, 2019 at 3:11 PM
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    2014 dcsb Trd Offroad
    Icon stage 5 and 295’s
    Buy the whole brisket, you can find 11 and 12 pound cuts. My grill is only 18 inches and it works pretty well. I get teased for picking a small one but do what works!
    jmdaniel and Oldie2007 like this.
  15. Jan 25, 2019 at 3:12 PM
    penbergm
    penbergm 86T4R
    Leander
    1986 4Runner 3.4l heart transplant
    Monstalined (Killer Beej & Jungle Love), 35's, 4.88's detriot rear, aussie front, tactical armor rear swingout, TG front w/ Smittybilt 9.5k winch.
    Well, found a torque converter but had to order & wait for delivery. So what do you do? Lights of coarse!694DE53D-4004-45E8-8A5B-806F17662544.jpg0D059313-AD48-4A1F-BD18-62FC382DE70A.jpgF7826507-CFC7-4912-B2C9-1BC1C776B172.jpgAC914569-0DF3-4440-ADE7-DB7008F876C7.jpg
    CedarPark, RobP62, Oldie2007 and 2 others like this.
  16. Jan 25, 2019 at 3:27 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Psych o Delic!!!! :rasta:
    RobP62 likes this.
  17. Jan 25, 2019 at 3:27 PM
    Oldie2007
    Kurt
    Lockhart, TX
    And on the 8th day, the guy said, "Let there be mud! That'll teach 'em!"
  18. Jan 25, 2019 at 3:30 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Kelly we busy but will get back wit ya
  19. Jan 25, 2019 at 3:30 PM
    jmdaniel
    Jeff
    Leander, TX
    SAUCE?!?
    Sixt8kupe, Oldie2007 and RobP62 like this.
  20. Jan 25, 2019 at 3:32 PM
    jmdaniel
    Jeff
    Leander, TX
    Zach will be along shortly to laugh at most of this...
