TTC ☆ OFFICIAL
Discussion in 'Texas' started by ChadsPride, Mar 28, 2018.
  1. Mar 5, 2019 at 10:16 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Oh, I just thought it might be someone that @LostHusker , or @Misplaced Nebraskan might have known back in the day!
  2. Mar 5, 2019 at 10:16 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    No just random google search
  3. Mar 5, 2019 at 10:17 AM
    Oldie2007
    Kurt
    Lockhart, TX
    I will admit that a Michigan redneck would have used PVC, because it's easier to repair! :anonymous:
  4. Mar 5, 2019 at 10:19 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    No, as far as I know it has always been @MarX but at one time his avatar was spongebob. Mike @Comatose and I were just curious if anyone has heard from him because the last post he made was New Years Eve.
    I actually started a conversation with him yesterday but haven't heard back yet.
  5. Mar 5, 2019 at 10:22 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Hey does anyone know anything about Gladewater? Thinking about moving there
  6. Mar 5, 2019 at 10:26 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Does it only do it on deceleration? Or acceleration too? Some people experience both. Typically though it is acceleration. Normally, as long as you lifted your truck 3" or less the ECGS Bushing will resolve the issue. If it wasn't there before but now is, that is likely the culprit. If it has been there all along, and your truck is relatively new, and the needle bearing is as new, then most likely the driveline is out, meaning you dramatically changed the driveline angles beyond the recommended 3 degree mark. That would require the drop or even shims on the rear axle. Usually not both.
    You could also get under it and try to shake the driveshaft to see if there is any play in the carrier bearing.
    Also, some people have been known to rotate the carrier bearing bracket 180 degrees (the bracket is offset to one side) which is just enough to get them under the 3 degree mark.
  7. Mar 5, 2019 at 10:29 AM
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
    I think ARB calls the bumper to frame brackets and fog light surrounds a "fitting kit"
  8. Mar 5, 2019 at 10:30 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    A Fitting Name I suppose. ;)
    RobP62, Nopro, Oldie2007 and 6 others like this.
  9. Mar 5, 2019 at 10:33 AM
    Pyrotech
    Pyrotech Well-Known Member
    And that is why it is being done... sometime I do learn from others mistakes...
  10. Mar 5, 2019 at 10:36 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    It's an Aussie term
    lupard, FastEddy59, Nopro and 4 others like this.
  11. Mar 5, 2019 at 10:37 AM
    Oldie2007
    Kurt
    Lockhart, TX
    I had to google it! Smaller than Lockhart, and that's saying something!
  12. Mar 5, 2019 at 10:39 AM
    Oldie2007
    Kurt
    Lockhart, TX
    Indeed, and Euro as well. All the lighting ballasts and lamps I used to work with are "gear", and anything that puts stuff together is "fittings".
  13. Mar 5, 2019 at 10:46 AM
    KENNY
    KENNY Well-Known Member
    I have no clue :notsure: I would assume a torch and lighter would give it that black look you are looking for :notsure:
  14. Mar 5, 2019 at 10:47 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    :devil: :spy: :fistbump:
  15. Mar 5, 2019 at 10:47 AM
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    2014 dcsb Trd Offroad
    Icon stage 5 and 295’s
    I thought you color matched your 2nd gen?
  16. Mar 5, 2019 at 10:49 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  17. Mar 5, 2019 at 10:51 AM
    KENNY
    It originally came with the base/dark grey color. I did the Duplicolor paint match stuff to that, but it chipped to shit from the flying rodents we call insects down here
  18. Mar 5, 2019 at 11:00 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    I reached out to tcbob about it.
  19. Mar 5, 2019 at 11:02 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Cool, thanks Mike! :thumbsup:
    I was gonna suggest I'd hit up Jason but the last time I messed with him he hacked my sig. :D
  20. Mar 5, 2019 at 11:05 AM
    Comatose
    Miguel
    San Diego, CA
    I cant let it go because it's a Navy thing for me... I don't like when people disappear and in the military it never bodes well. Plus the date of his last post coupled with his sudden disappearance is more than coincidental and concerning.
