TTC ☆ OFFICIAL
Discussion in 'Texas' started by ChadsPride, Mar 28, 2018.
  1. Sep 23, 2019 at 10:25 AM
    Austinguy
    Austinguy #FreeManer
    Robert
    Texas
    First on race day!
    Secrets
    RobP62, Mr.Pain and MattCowsmasher like this.
  2. Sep 23, 2019 at 10:32 AM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Yo I got a bunch of first gen shit I can sell ya for cheap. Let me dig when I get home
  3. Sep 23, 2019 at 10:33 AM
    HCFab
    HCFab Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    Still have my #? I'll look to see if I can find yours.
    Oldie2007 and CedarPark[QUOTED] like this.
  4. Sep 23, 2019 at 10:40 AM
    CedarPark
    Dylan
    Cedar Park, TX
    Shoot me a text. Got at least a diff drop and some heavy duty steering bushings I’ll let go cheap
    Oldie2007 and MattCowsmasher like this.
  5. Sep 23, 2019 at 11:01 AM
    penbergm
    penbergm 86T4R
    Leander
    1986 4Runner 3.4l heart transplant
    Monstalined (Killer Beej & Jungle Love), 35's, 4.88's detriot rear, aussie front, tactical armor rear swingout, TG front w/ Smittybilt 9.5k winch.
    One thing to consider here. This is JUST a fuse box. A relay/fuse box is often more practical. With a relay, you can run low amp through your switches to activate a relay. Then the relay can provide full amperage from your battery to supply the load (ie. lights, etc). And it still doesn't need to break the bank.
    https://www.amazon.com/dp/B07GT3VKB8/ref=psdc_15733511_t3_B072KJNPHJ
  6. Sep 23, 2019 at 11:54 AM
    Austinguy
    Robert
    Texas
    First on race day!
    Secrets
    So are relays necessary for the setup I was describing? Can I just wire relays in as needed? I know my big light bar up front has a relay already. I guess I need to see which other of the lights will need one?
    Oldie2007 and RobP62 like this.
  7. Sep 23, 2019 at 12:08 PM
    imthejaybird
    imthejaybird I make things and do stuff. TTC #287
    Jay
    Burleson, Tx
    2006 Tacoma DCSB
    I wire everything to relays. I do this for a few reasons. I don't need to run a high amp switch, or heavier gauge wire inside the cab of the vehicle. It keeps all that in the engine bay, where it should be. The lighter gauge wire is easier to manage inside the dash also. So far, I'm only running lights but plan to add a compressor and CB radio before too long and that's where the relay will come in handy.
    Oldie2007, RobP62, FastEddy59 and 2 others like this.
  8. Sep 23, 2019 at 12:35 PM
    penbergm
    penbergm 86T4R
    Leander
    If you’re looking for clean, best to keep it all together. Otherwise you have a fuse here & a relay there.
  9. Sep 23, 2019 at 12:38 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Not necessary, but, another fail safe. Depending on how much you are going to do, a circuit breaker or two would also be a good safety consideration. You could wire them into the hot side so if a fused link fails or switch goes out it will scram the system and keep you from being stranded.
  10. Sep 23, 2019 at 12:43 PM
    Austinguy
    Robert
    Texas
    First on race day!
    Secrets
    Okay now who wants to help me put together an Amazon shopping list?:D
    Oldie2007, RobP62 and MattCowsmasher like this.
  11. Sep 23, 2019 at 12:45 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    If ya want a clean install. Ask @LostHusker to send ya some pics and info. Dam fine job he did.
  12. Sep 23, 2019 at 12:59 PM
    Pyrotech
    Pyrotech Well-Known Member
    Here is a very good thread on auxiliary fuse blocks. goes into a lot of good information and well worth reading.
    but yes something like that would work. just make sure it can handle the total current or amps you will run at at the same time.
    if your lights only have a watt rating. then ohms law is your friend
    Amps = Watts/Volts
    make sure you use relays for high load items so you don't burn switches up.
    use a good quality crimper and try to avoid soldering crimped connections. it can lead to the wire breaking if not done right.
    Oldie2007, RobP62, Beretta4x4 and 2 others like this.
  13. Sep 23, 2019 at 1:00 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Pick your poison my vote is spod for simplicity.:evil:
    Spod Universal Truck Kit With Universal Fuse Box Source Mount And Modular 6 Switch Panel - 700-MOD https://www.amazon.com/dp/B01N7PNP53/ref=cm_sw_r_cp_api_i_YpsIDbGPG21D8
    WATERWICH 6 Gang Switch Panel Electronic Relay System Circuit Control Box Waterproof Fuse Relay Box Wiring Harness Assemblies For Car Auto Truck Boat Marine (Universal 6 gang button switch panel) https://www.amazon.com/dp/B0749D7G8B/ref=cm_sw_r_cp_api_i_orsIDbDWBD21B
  14. Sep 23, 2019 at 1:04 PM
    Pyrotech
    check my build thread, there is a couple post i made on my custom wire harness work for the horn setup and the rock lights and the ongoing fuse block setup I am working on as well, even though there is not many details on that. yet..
    https://www.tacomaworld.com/threads/the-some-day-build-and-trip-log.599494/page-2#post-20916282
    https://www.tacomaworld.com/threads/the-some-day-build-and-trip-log.599494/page-5#post-21551086
  15. Sep 23, 2019 at 1:10 PM
    Pyrotech
    I grab a 7200v line with my hands the other day... :rofl: best be sure you don't have a a hole in your rubber gloves.
    and was in between two 7200v phases, contact with both would have put 12470v into me and pushed the limits of my rubbers
  16. Sep 23, 2019 at 1:13 PM
    Pyrotech
    and make sure to save this somewhere safe. it may be needed years down the road, and makes troubleshooting so much easier
  17. Sep 23, 2019 at 1:35 PM
    ThorsTRD
    ThorsTRD Pretty good at F'n shit up.
    Nick
    Fort Worth
    2021 TRDOR DCSB
    Let's just call it my 401K.
    Anybody got a chunk of land or a side of their house they'd let me set up camp in my RTT around COTA or remotely close for the F1 race? It's the weekend of Nov 1st, Friday and Saturday night. I wouldn't need anything more than a parking space and it would just be me, no pets or other people. TIA guys/gals.
    Oldie2007, ChadsPride[OP] and Nopro like this.
  18. Sep 23, 2019 at 1:42 PM
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    What did I do?
    :anonymous:
    Oldie2007, penbergm, RobP62 and 2 others like this.
  19. Sep 23, 2019 at 1:57 PM
    Nopro
    Nopro Rhino pilot
    Stopher
    Pflugerville
    2014 dcsb Trd Offroad
    Icon stage 5 and 295’s
    They usually have camping areas around the track. A friend of mine camped for the x-games a few years ago.
  20. Sep 23, 2019 at 3:04 PM
    CarmenSanDiego
    CarmenSanDiego Battle Tank
    Kelly
    Dickinson, TX
    2011 MGM 4Runner Limited 4x4
    Bilstein 5100's OME HD Springs Shrockworks Sliders Addicted Offroad Front Bumper Proline 4x4 Rear Bumper CBI skids Black Rhino Armory wheels
    My mom joined the Toyota family this weekend with her baller new Highlander. She's super happy with it!
