TTC ☆ OFFICIAL
Discussion in 'Texas' started by ChadsPride, Mar 28, 2018.
  1. Sep 23, 2019 at 8:28 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Same, not a guru, but I have been known to connect a few wires.
    RobP62, FastEddy59, ballataco and 3 others like this.
  2. Sep 23, 2019 at 8:30 AM
    Austinguy
    Austinguy I love God, My Family and My Country!
    Robert
    Leander, Texas
    2015 Tacoma TRD-Offroad DCSB
    ARB OME 885 Springs, Bilstein 5100s, Heavy Metal AAL, 285/70/17 Goodyear Duratracs, 32" Led Light bar in lower grill, Anytime fog light mod., CBI Ditch Lights, More to come!
    Cool. Main question is, “What is the best, safest, cleanest way to connect all the wiring for my add on lights?”
    I currently have a front light bar but I am adding a few more things this week. I’ll be adding ditch lights, under hood lights, bed lights and I’d like to figure out how to wire in the led lights in my RTT with some sort of quick disconnect.
    I’ve seen people use things like this... is this what I need?
    Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover https://www.amazon.com/dp/B001P6FTHC/ref=cm_sw_r_cp_api_i_AtoIDb52332KK
    RobP62 likes this.
  3. Sep 23, 2019 at 8:30 AM
    Gixerkiller
    Gixerkiller Back in the real murica TTC #0043
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Don’t like to admit it, but, that is one of my strong suits...depending on what you are after...
    RobP62 and Austinguy like this.
  4. Sep 23, 2019 at 8:32 AM
    Austinguy
    Robert
    Leander, Texas
    RobP62 likes this.
  5. Sep 23, 2019 at 8:33 AM
    Gixerkiller
    Dennis
    Taylor, TX
    If you are running more than one system it always advised to run a power distribution block for cleanliness, service, and maintenance. You don’t have to, just be sure to fuse everything.
    RobP62, Pyrotech and Austinguy like this.
  6. Sep 23, 2019 at 8:38 AM
    lilred95
    lilred95 TTC #014
    Cody
    Leander TX
    95 tacoma 5spd 2.7 4wd "Scarlett" 06 Lexus GX470 "Sexy Lexi" 14 Yz450f 06 ttr230
    need more
    Will have TTC wood coasters at the show available ! $20 in person set of 4 $25shipped
    Mirror coasters $10 each in person will ship lower 48
    Got some others in the making now !
    RobP62, T4Rgurl, EPBlueTaco and 4 others like this.
  7. Sep 23, 2019 at 8:45 AM
    Austinguy
    Robert
    Leander, Texas
    So the one I linked to...is that a decent product that you would recommend?
    @Texoma @Gixerkiller @Pyrotech
    RobP62 and MattCowsmasher like this.
  8. Sep 23, 2019 at 8:53 AM
    Beretta4x4
    Beretta4x4 2-28IN, 172IN, The Guy Next to Fire Guy TTC #0114
    Josh
    Temple, TX
    Super White 09 TRD Off-Road A/C M/T
    255/85R16 Cooper ST-MAXX Pro-Comp 16" Series 7031 Rims OME 3" Lift, 886 Front Springs, Dakar Rear Leaf Spring Pack OME Nitrocharger Shocks with Rock Guards Sway-bar Delete ARB Deluxe Winch Bumper Warn M8000S Winch 4xInnovations Sliders and Skids Spyder Headlamps Baja Designs Fogs and Ditch lights Softtopper Cobra DX 19 CB w/ 4' Firestick 62" Hi-Lift on Armortech Off-road Bed rail mounts TTC Member #0114 https://www.instagram.com/texastoyotacoalition/ https://www.tacomaworld.com/threads/ttc-%E2%98%86-official.541185/page-1097#post-18444872
    I'm using that fuse panel.
  9. Sep 23, 2019 at 8:54 AM
    Gixerkiller
    Dennis
    Taylor, TX
    Definitely. Unless you want the ultimate...
    The SPOD.
    Be sure to use high grade wire meant for automotive use and power usage.
    Usually O gauge from batt to input line then split down for each section based on amps/watts/ohms required.
    Even the wiring from the lights should be checked to ensure the load ability is there, if not you can end up with melted wires and shorted systems. DO NOT use the twist and tape method or the house wire nut route. Heat shrink and solder.
  10. Sep 23, 2019 at 8:54 AM
    Austinguy
    Robert
    Leander, Texas
    So that would be an affirmative then?
    Can you share pics of it installed? I’d love to see where and how you mounted it.
    RobP62, MattCowsmasher and Beretta4x4 like this.
  11. Sep 23, 2019 at 8:58 AM
    Austinguy
    Robert
    Leander, Texas
    Solid advice man. I will keep all that in mind as I work through this. I am a total novice at wiring so I’ve purchased wire kits with everything I have bought. I feel like that is the safest route as they should know what is required for their lighting systems.
    The one thing I’m still looking for is a way to install a plug in the bed for my RTT led lights. I’ll have to look but I believe there are a few different connector types included with the setup. Anyone know of a good write up for this?
    RobP62 likes this.
  12. Sep 23, 2019 at 8:59 AM
    Beretta4x4
    Josh
    Temple, TX
    I have to worry about space on that side because of my clutch master cylinder. I mounted mine to the top of my factory fuse block so everything is in one space.
  13. Sep 23, 2019 at 9:00 AM
    MattCowsmasher
    MattCowsmasher TTC #0010
    Temple, TX
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, long legged, big tars, debadged with a hood skewp
    I’m not a electrical guy so I used something dummy proof called a Spod once you set up the switches and control box it’s literally plug your accessories into the + and - then the magic happens.
    I got mine used they are about 400 new fwiw.
    Austinguy likes this.
  14. Sep 23, 2019 at 9:05 AM
    MattCowsmasher
    Temple, TX
    @Austinguy
    Here’s a few pics of my spod setup it’s the basic one you can get fancy with touchscreen and even Bluetooth I believe.
    You can the dusty black box behind the battery
  15. Sep 23, 2019 at 9:06 AM
    Austinguy
    Robert
    Leander, Texas
    Ty Josh. That’s approximately where I’m looking to install. I don’t have clutch stuff to worry about so I have a bit more room.
    Beretta4x4 and MattCowsmasher like this.
  16. Sep 23, 2019 at 9:08 AM
    Austinguy
    Robert
    Leander, Texas
    Very nice Matt. That’s a nice chunk on change there considering the blue sea setup is like $40. I may just go the blue sea route and get a little help from someone who knows what their doing. I’m too cheap:anonymous:
    Beretta4x4, Nopro and MattCowsmasher like this.
  17. Sep 23, 2019 at 9:11 AM
    MattCowsmasher
    Temple, TX
    I don’t blame you I got a killer deal on it is why I went with it. Plus some passengers like to mash the switches it gets annoying at times.
    Beretta4x4 and Austinguy like this.
  18. Sep 23, 2019 at 9:13 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    I know enough not to piss on an electric fence.
    potthoffw, Nopro, ballataco and 2 others like this.
  19. Sep 23, 2019 at 9:16 AM
    Austinguy
    Robert
    Leander, Texas
    Same here
    jmdaniel likes this.
  20. Sep 23, 2019 at 9:17 AM
    Austinguy
    Robert
    Leander, Texas
    Man you find good deals on everything!
    Lol. I can imagine that would be annoying! You just have to slap their hand a few times
    MattCowsmasher likes this.
