Tucson Tacoma owner needs advice w/lift
Discussion in 'Arizona' started by lizard1, Jun 19, 2012.
  1. Jun 19, 2012 at 3:22 PM
    lizard1
    lizard1 [OP] Well-Known Member
    Tucson
    Desert Sand Mica/4x4 off road w/lock rear
    Leer cap, rear TSB, BFG All Terrains 10 ply 265/75/16, mud flap trim, black badges, AFE filter, 3" Toytec lift, 884 OME coils, add - leaf, Bilstein 5100 all around
    I'm hoping I get some feedback from some local Tacoma owners in Tucson or Phoenix. I would like to lift my Tacoma about 2''. Nothing extreme nor do I intend to upgrade to larger tires.
    My current set-up : '08 TRD 4x4 off road. Tires: 265/75/16 BFG AT 10 ply
    Bilstein 5100's front set at 1.75''
    Rear TSB leaf spring upgrade
    I've read suspension threads extensively about lifts and there are so many pros and cons....I'm thoroughly confused and somewhat frustrated.
    I'm willing to spend close to a grand but obviously would like to go cheaper - but not sacrifice the integrity of my trucks drive-train or other suspension components (cv boots, watcha-macall-its and thing-a-ma-jigs) or impact riding behavior significantly.
    My off road use is primarily dirt, rutted, rocky roads. Some low 4 engagement in rough washed out roads, mud and sand. No rock crawling or Moab, Utah touring. Primarily because I don't have a lot of experience off roading.
    90% of my travel is pavement, remainder is hunting excursions or Redington Pass type drives (for those of you in Tucson) Reason for lift: It looks good and a little more clearance - mainly for looks though!
    I would be grateful for any suggestions or recommendations , in simple terms, (my mechanical knowledge is limited) to maybe lead me in the right direction.
    Sorry it's so damm long.....I'm at my wits end. Thanks, Rocky
  2. Jun 19, 2012 at 3:31 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    I just put a OME kit on my father inlaw's truck. I put 885 coils and OME struts with the Dakar leaf pack and new OME nito shocks. His use of the truck closely resembles what you stated. He loves it so far and it has been about 4 months. He said It rides smoother than it did stock. He is still running on stock tires right now and the truck in my opinion does not look miss proportioned. He bought everything from Will at Sierra Expeditions in Tempe.
  3. Jun 19, 2012 at 3:51 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Redington pass is really rutted. My friend had a 4runner that had Icon coilovers in the front and OME out back. That was by far the best ride I had on that trail, and even then on the way back the Icons got heated and ride quality started to suffer. I have em on my Truck and rutted roads they are amazing. A little rough on the street but I have em cranked to about 2.75"- 3" of lift.
  4. Jun 19, 2012 at 3:52 PM
    2012 Tacoman AZ
    2012 Tacoman AZ super n00b
    Phoenix, AZ
    4x4 Taco
    I'm sure I will get flamed for this but here goes anyway.
    Just get an Add a Leaf and front spacers w/diff drop. I wheel the shit out my AAL and front spacers and no problems yet. And its hella cheap. Besides you going mainly for looks anyway so this would be your best bet. $40 for front spacers and $40 for AAL and your done.
    One day I will upgrade to a real suspension but I have put my current setup through its paces and and no problems at all. Front still rides like stock and the back is a little stiffer but still not bad at all.
  5. Jun 19, 2012 at 4:00 PM
    Zombie
    Zombie I miss my Taco
    Tucson, AZ
    06 4x4 double cab (Sold)
    I say Old Man Emu. Rides better then stock.
    BTW: Us Tucson members aRe having a meet Thursday.
  6. Jun 19, 2012 at 5:00 PM
    lizard1
    Tucson
    Thanks! So I would remove/sell my current Bilstein 5100's. Is the lift 3"? If so, is there drive-line vibrations at certain speeds? Also, are the cv boots angled too much?
    Do I research OME kit or are the components purchased separately? Finally - ballpark cost estimate...I know, I'm a P.I.T.A. Sorry man....but do appreciate your input.
  7. Jun 19, 2012 at 5:01 PM
    Revtek
    Revtek Member
    Oregon
    Revtek Tacoma TRD
    3" Revtek Lift, Revtek Behind the Grille Mount, Revtek Light Bar Mount, Mamba Wheels, Trail Grappler Tires, Bed Slide, Trex Grille, Piaa Lighting
  8. Jun 19, 2012 at 5:03 PM
    lizard1
    Tucson
    That was my original plan but the responses were pretty negative in the suspension threads. I may still do what you did - need opinions from co-workers....THANKS!
  9. Jun 19, 2012 at 5:19 PM
    2012 Tacoman AZ
    Phoenix, AZ
    4x4 Taco
    Because this form and others like it are people that are more hard-core. They will always push you towards a full suspension. But in many cases that's not always necessary.
    However I have had spacer lifts on both my previous Xterra and now my Tacoma and have never had a problem with them.
    I have wheeled this Tacoma pretty hard I don't do crazy rock crawling or 80 mile an hour pre-running but the 4x4ing that I have done - I would consider at least moderate maybe even hard, and still never had any problems.
  10. Jun 19, 2012 at 6:49 PM
    05TacoRunner
    Peoria, Az
    I believe you could set your bilsteins to 0 lift and add the OME 885 coils. Then you would need to purchase the Dakar leaf packs. We installed a carrier bearing spacer but never noticed a vibration before or after. If I were you I would give Will at Sierra Expeditions a call and tell him exactly what you are looking for, your intended uses,expectations and price range.He will steer you in the right direction. He test everything he sells and has to back the product before he sells it.
  11. Jun 19, 2012 at 6:57 PM
    05TacoRunner
    Peoria, Az
    Depends on the spacer placement. If you install the spacer on the top of the coilovers it does not affect spring rate and will ride close to factory. It does however push the coil over down technically making it longer. Therefore unless you extend your bump stops you will bottom out the shock before reaching the bumps. If you extend the bump stops to prevent this you will loose up travel. Now if you install the spacer on the coil under the coil over mount you will compress the spring more to install them. That adds preload to the spring causing a stiffer spring and a harsher ride. So you have to decide what you are willing to sacrifice when going spacer lift.
  12. Jun 19, 2012 at 7:58 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    OK, I have wheeled everywhere around Tucson as I am there. I had Eibach springs, Bilstien 5100's and Toytec AAL in back. If you want 2" that can do anything around tucson, go that route. Its quick, easy, cheap, and will ride better than stock. I can easily help you install it as I did it in mine before I went crazy with my truck.
    Lizard, check your PM.
  13. Jun 19, 2012 at 8:17 PM
    2012 Tacoman AZ
    Phoenix, AZ
    4x4 Taco
    X2 Will is good people!
  14. Jun 19, 2012 at 10:19 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Pretty much what everyone said. At that pricepoint there isn't too much you can do, general consensus from what I've gathered is OME seems to be the best way to go.
    That said, I can fly down Reddington like, well almost butter doing 70+ in spots with my Fox setup... muahaha.
  15. Jun 20, 2012 at 1:13 AM
    AZconquistador
    AZconquistador Member
    salvador
    Tucson az
    2012 prerunner trd off road
    MB stryker black/chrome rims, smittybuilt black steps, Airaid cold air intake, flow master exhaust
    I can have a lift :/
  16. Jun 20, 2012 at 3:26 PM
    lizard1
    Tucson
    All good stuff!! All that info/feedback is what I was looking for. I plan on meeting other Tacoma owners Thursday at 7pm - in Tucson. Am hoping to pick some brains for additional knowledge.
    All replys I received have been helpful and I'm grateful...THANKS MUCHO!
  17. Jun 20, 2012 at 4:41 PM
    congicus
    congicus Well-Known Member
    mike
    Tucson
    2011 4x4 SR5
    Well If you go with a spacer lift I have a full setup from daystar you can have including rear shocks and what not, i really just want it out of the garage
