Tuff Country 85250 AAL
Discussion in 'Product Reviews' started by fla_sun, Oct 30, 2018.
  1. Oct 30, 2018 at 1:58 PM
    fla_sun
    fla_sun [OP] Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Installed this 2" lift AAL on an '06 4X4 Tacoma.
    The springs are about 26" long so they easily fit in the (pathetic) TSB spring pack. Actually could have been 8" longer and still fit.
    The kit came with very long quality looking center bolts. They had to be cut off about 4" when installed. I used the new nuts as they were SS.
    The ends of the new springs had some rust so that was taken care of before the install with a shot of paint.
    The springs came with plastic push in bushings on each end for metal to metal squeak I assume.
    The lift results were actually 3.5" which I hope will settle down with time. I lost 1.5" when the TSB springs were installed.
    I reused the original U bolts as they were plenty long for the added height.
    My Airlift bags went back to 5-8 PSI normal setting (from 20-22 PSI after TSB spring upgrade) and the rear Timbren bump stops now have adequate clearance.
    Note:
    Due to the amount of lift in the back it looks like some Bilstein 5100's in the front set on .85" will be most likely needed. Was trying to avoid this but WTH, comes with the territory.
  2. Oct 30, 2018 at 11:49 PM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    How’s the ride?
  3. Oct 31, 2018 at 3:22 PM
    Navigator1
    Spokane WA
    18 TRDORDCLBCEMENT
    Thanks for the review.
