Tuff Country Lift Removal, switch to Bilstein 5100's
Discussion in 'Suspension' started by Thetoolman, May 20, 2013.
  1. May 20, 2013 at 9:28 AM
    Thetoolman
    Thetoolman [OP] Member
    Tim
    Victoria, BC
    02 Prerunner 2wd V6
    Tuff Country Lift K&N Air filter and intake
    Hey everybody,
    I just joined this site, I've been creeping it for a lot of info regarding my truck and figured I should join up and ask some questions. My name is Tim and I live in Victoria, B.C.
    I recently bought an 02 Tacoma (2WD, Prerunner, Double cab) that came with a crappy lift that the previous owner installed (Tuff Country) and after driving it for a while I got fed up with the terrible ride and bought some Bilstein 5100's. I dont want to keep the truck lifted, I want to put her back to stock height, except I want have it ride level. Here comes my question: What preset do I put on the struts to keep it riding level? They have 3 settings (didn't come with instructions, but from my creeping im guessing the settings are: 0, 1.75, 2.5)
    More info:
    Struts part # BE5-D558-T0
    Shocks # BE5-D559-T0
    BE5-D560-T0
    Gap between rear tire and wheel well: 9.5"
    Gap between front tire and wheel well: 9"
    Truck has a canopy installed
    Thanks in advance for your help!
  2. May 20, 2013 at 9:43 AM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    They don't have the .85 inch setting for first gen tacos?
  3. May 20, 2013 at 9:47 AM
    Thetoolman
    Tim
    Victoria, BC
    02 Prerunner 2wd V6
    That sounds like it would make more sense than 1.75" considering the distance between the presets. To be entirely honest I'm not sure though. The distance between the grooves is 9/16"
  4. May 20, 2013 at 9:48 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    or according to toytec
  5. May 20, 2013 at 9:51 AM
    BulletToothTony
    Thanks for the pic brock, I'd set it at the 1 inch setting that should be the closest for you...
  6. May 20, 2013 at 9:58 AM
    Thetoolman
    Tim
    Victoria, BC
    02 Prerunner 2wd V6
    Thanks fellas,
    I'll post some pics when the work is done.
  7. May 20, 2013 at 10:09 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    ur welcome
  8. May 26, 2013 at 9:28 AM
    Thetoolman
    Tim
    Victoria, BC
    02 Prerunner 2wd V6
    Did the install yesterday, after the struts settled down a bit the front is 1" higher than the rear. Damn... I guess the canopy does factor in quite a bit of weight. Time to pull the struts and move the clip.
