Tufskinz Mud Flaps?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MissoulaGriz, Oct 6, 2020.
  1. Oct 22, 2021 at 6:51 AM
    #61
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Early trucks had 4WD on them. My 85, 92, and 99 did. Kinda bummed my 3rd Gen came with blank ones, maybe I’ll upgrade when they get ripped off.
    pic of random 80s something
    My ‘99….not sure when they went to 4X4 on the mud flaps from the factory, 2nd Gen, maybe?
  2. Oct 22, 2021 at 10:06 AM
    #62
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    I figured out my problem. My driver rear flap was previously knocked off and the dealer reinstalled using different length hardware. No wonder it was knocked off twice.
  3. Oct 22, 2021 at 10:09 AM
    #63
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I wonder if these will fit the 2nd gen. I took my oem mud flaps off since I broke two of them on the trails. Almost bought the rokblox or whatever but didnt commit because none of them had 4WD on them.
  4. Jun 27, 2022 at 10:30 AM
    #64
    batcat420
    batcat420 I'm a Blue Ribbon man.
    Scott
    Atlanta
    2022 Lunar Rock SR5 Trail Edition
    Bumping this thread. Does anyone have pictures with the 4WD logo in Lunar Rock, or the tri-color stripes up the side?
  5. Jul 11, 2022 at 1:18 PM
    #65
    batcat420
    Scott
    Atlanta
    I dig 'em! The instructions were a little off, but nothing major. I should've read this thread a bit closer before installing because a completely wrecked one of the plastic wheel well pins that the provided screws go into. Tried removing it without realizing it needed to stay.
  6. Sep 19, 2022 at 9:56 AM
    #66
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    It looks like the front flaps are shorter than the rears which my OCD couldn't handle! Can anyone measure the fronts and rears from the bottom of the fender flare to the bottom of the flaps? I see they can make custom length ones but I wouldn't know what lengths to request without measurements. Thanks!
    Flash1034 likes this.
  7. Aug 12, 2023 at 9:13 AM
    #67
    MissoulaGriz
    MissoulaGriz [OP] Well-Known Member
    Missoula
    ‘19 SR5 DCSB Super White
    Update:
    One of my rear Tufskinz flaps cracked along the mounting hole. No big deal, these things happen so I emailed them to ask about a custom size order. They got back to me right away saying they don’t really do custom size orders anymore but they were curious about my cracked rear flap.
    I told them it just cracked for some reason other than by off-roading and I sent them a pic.
    By the next day they asked me to confirm my address because they were sending me out a replacement set for the rear at no charge!
    That’s pretty great customer service.
    Taco_mike73 and soundman98 like this.
  8. Aug 12, 2023 at 11:04 PM
    #68
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    Just got these, and was hoping the fronts wouldn't rub, but they do. I have arouns 2.5" lift with 285-70-17 on a -10 offset wheel. I had emailed them asking if they will rub up front and they said no and referred to a pic on the product page of a truck with 33's. If they were molded to the contour of the wheel well theyd by fine, but the flat design with the spacer means you lose about an inch of clearance in the wheel well
  9. Aug 13, 2023 at 6:38 AM
    #69
    MissoulaGriz
    Missoula
    Oh man, that’s a bummer! I was really close to rubbing on my new 265 75 16 KO2’s on the front most inner screw with it being flat. What I did is took the old screws and spacers from the pair of rear flaps Tufskinz replaced and used those for the front inside mounting hole. That bent the inner corner in and gave me back about half an inch and now I’ve got plenty of clearance.
    Not sure if that will work in your case with the 33” but may be worth a shot.
    I’ve seen people do this with RekGen flaps also.
  10. Aug 13, 2023 at 8:29 AM
    #70
    808stateofmind
    Kona
    Ok, good to know. I was thinking of maybe taking a heatgun to the flap and trying to mold it to fit the wheel well better, but not sure how good that will work
  11. Oct 22, 2024 at 4:11 PM
    #71
    TRDaddio
    TRDaddio Well-Known Member
    2024 TRD Sport
    None
    Has anyone installed these on a 24 Tacoma yet?
  12. Jan 4, 2025 at 7:25 PM
    #72
    Bigeshorte45
    Bigeshorte45 Well-Known Member
    VA
    2017 DCSB 4x4 Sport
    Replaced old Amazon/ebay/stock flaps with Tufskinz today. Some before/after pics below for reference.
    Old/New
    #72
    Fast1 and Taco_mike73 like this.
  13. Jan 5, 2025 at 7:27 AM
    #73
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    Anyone try these on an SR yet?
    SRs don’t have flares so I’m wondering if mounting is different or even possible. I’m sure I can make a set “fit” but options for SR specific flaps are limited and not so great. I like the idea of these much better.
  14. Jan 5, 2025 at 12:49 PM
    #74
    Rrr70
    Rrr70 Member
    2021 ACLB
    Taco_mike73 and RIX TUX like this.
  15. Jan 5, 2025 at 8:18 PM
    #75
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    how come?
    #75
  16. Jan 5, 2025 at 8:20 PM
    #76
    RIX TUX
    what does their website say?
  17. Jan 6, 2025 at 7:57 AM
    #77
    Bigeshorte45
    VA
    2017 DCSB 4x4 Sport
    TLDR: Wanted to buy something new for truck and also see if they helped with front wheels rubbing.
    Long Story: Two reasons: Paid the truck off last month :D so I wanted to buy something new for the truck. I recently replaced my 265/70/17 Falken Wildpeaks that were on my Tacoma Sport stock wheels with 265/70/17 BFG Trail Terrains mounted on 4runner TRD OR wheels. Ever since the new tires were put on, the front wheels have been rubbing the stock mud flaps when turning in reverse, or braking while turning (while moving forward, turning, braking, and compressing the front struts). So I also wanted to give these a try to see if they helped with rubbing. Truck has been parked since I installed them this weekend, so I'll find out this week if the flaps helped with that or not.
    RIX TUX[QUOTED] likes this.
  18. Jan 6, 2025 at 11:55 AM
    #78
    JONSEY84
    JONSEY84 New Member
    2018 TACOMA TRD OFF ROAD
    2” Lift all around BILSTIEN 5100’s, MEDIUM DUTY OME COILS ICON AAL IN THE REAR 285/70/17 WHEEL TIRE COMBO CERAMIC TINT ALL AROUND, 43% WINDSHIELD 5% FRONT DOORS 2.5% REARS
    I’m gonna try a set of kick backs, I’m pretty sure they will b the only mudflap that will fit without rubbing, I’m running 285/70/17 on my Tacoma. Those were the only style mudflaps I could run on all my half tons to mitagate the rubbing issue but still have a flap, I do have PPF on my rockers and lower doors but don’t wanna ruin that n have to replace it either.
  19. Jan 6, 2025 at 2:13 PM
    #79
    RIX TUX
  20. Jan 6, 2025 at 2:26 PM
    #80
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Bigeshorte45 and RIX TUX[QUOTED] like this.
