Tundra Axle Swapped First Gens?
Discussion in '1st Gen. Tacomas (1995-2004)' started by G59, Sep 8, 2019.
  1. Sep 8, 2019 at 4:06 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Anybody do it? Thinking about it but I'm not sure of everything it involves (drilling, welding, fab, leaf spring compatibility). Looking to gain some track width for the rear of my truck but I have no idea how this axle swap goes. I know a lot of people have done it but I'm curious as to what it entails...
    :help::cheers:
  2. Sep 8, 2019 at 10:08 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Anyone?
  3. Sep 8, 2019 at 10:09 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    New perches, maybe brake lines set up, make sure you have the right gear ratio.
    No stock lockers
  4. Sep 8, 2019 at 10:13 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Good point. Didn't think about the gear ratio. Thanks for the input!
  5. Sep 8, 2019 at 10:14 PM
    JKO1998
    Utah
    I think a lot of tundras came with 4.10’s just like Tacoma’s, so not a big deal
  6. Sep 8, 2019 at 10:34 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I have it, many guys have done it. T100 is the sane axle too. New perches and shock mounts, iam long travel so all that had to be new for the spring under. Well worth it.
    G59[OP] likes this.
  7. Sep 8, 2019 at 10:37 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It’s not exactly a popular mod, at least I don’t hear about it too often. Most people I see who end up doing some custom axle set up end up with danas or rock assaults or somehing.
    If you just want more track width, just get some spacers.
    G59[OP] likes this.
  8. Sep 8, 2019 at 10:52 PM
    eon_blue
    Azusa, CA
    1st4x4 and G59[OP] like this.
  9. Sep 9, 2019 at 4:03 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Yup I did this cut old perches off weld new ones on. Most people that do it go for spring under I stayed spring over axle. You will have to get the ebrake cable with the tundra axle and find a way to connect it to your Tacoma I used random parts I had laying around my shop. Brake line is the same. Not sure on the load proportioning valve as I had already deleted that and installed a manual valve with a knob.
