Tundra Big Brake Kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by AZHornet, Aug 13, 2013.
  1. Aug 13, 2013 at 9:41 PM
    AZHornet
    AZHornet [OP] Well-Known Member
    Michael
    Scottsdale AZ
    White Tacoma 4x4 AccessCab
  2. Aug 14, 2013 at 8:32 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Holy shit!!! I have tundra brakes on my taco, but I wouldn't pay over a grand for them haha. I believe it was about $500 for them with ebc pads and rotors.. Couldn't be happier with them
  3. Aug 14, 2013 at 8:49 PM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    I put 2001 tundra calipers (199mm) rotors and pads on my 97 reg cab and its kick ass! Total cost was @ $210. I wouldn't do anything else except maybe the 231mm tundra calipers. I am running 33's and the stopping power is 200% of what it was stock.
  4. Aug 14, 2013 at 10:53 PM
    AZHornet
    Michael
    Scottsdale AZ
    I agree its a bit pricey...im looking to do the Tundra upgrade myself..just curious to see what the TRD Rotor size is in comparision...
  5. Aug 14, 2013 at 11:21 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Do you suggest OEM Tundra calipers? What aftermarket brands would you go with?
  6. Aug 15, 2013 at 7:04 AM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    Look on eBay for calipers. 199mm are p/n S13WE. 231mm are p/n 13WL. The 199mm calipers can be found as low as $40 each shipped. Then get some powerstop rotors and ceramic pads from rockauto.com for $97. You have to modify the banjo bolt for the brake line and bend the dust shields back a bit. Then you have kick ass stopping power.
    There are some detailed write ups on yotatech forums. Google is your friend on this one. :D
  7. Aug 15, 2013 at 7:18 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I got a used set of 13WLs on here, bought a rebuild kit from Camelback Toyota for maybe $20. Rebuilt and painted the calipers and then went with OEM rotors and pads from the dealership. I also decided to use this time to upgrade my brake lines (you can loose a lot of stopping power when those rubber hoses wear and expand), and I didn't have to drill out the current hose. I think I spent about $400.
    The stopping power is amazing. I think the TRD brake kit is way overkill, and although overkill is good, the price to overkill ratio is not appropriate.
    I got the calipers used for $80 for both and I think new/rebuild calipers are $200+ each.
  8. Aug 15, 2013 at 10:52 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Im familiar with the writeups, was just wondering if most people were going oem or not.
  9. Aug 15, 2013 at 11:03 AM
    AZHornet
    Michael
    Scottsdale AZ
    Chipskip...did you have any clearance issues with your wheels? Im running some 16" TRD rims of some vintage...I believe I may have the 199mm's right now..(bought the truck from a buddy of mine)...I may look to do the update to the 13WL's...the upgrade to 233 mm's may be worth the jump...with that being said..im going to stop by the dealer to see the deal with the TRD Kit...:)..I will post back their response.
    Michael
  10. Aug 15, 2013 at 11:21 AM
    AZHornet
    Michael
    Scottsdale AZ
    that along with the steel lines and ADOT blue fluid rocks
  11. Aug 15, 2013 at 12:52 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Those TRDs are stoptechs. Nice but too pricey given the alternatives such as Speed Freaks Willwood kit.
    I was alwasy under the impression the Tundra upgrade was less bolt on. Sounds so easy and cheap I can't imagine going any other route.
