Tundra brake caliper question!! Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Junetaco03, Nov 19, 2017.
  1. Nov 19, 2017 at 7:52 PM
    Junetaco03
    Junetaco03 [OP] Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    I just got a pair of tundra calipers model is 13wl I’ve been doing research online and can’t find the answers I need. I just wanted to know what year and model tundra they are for since I have to buy new brakes pads for it. Thanks
  2. Nov 19, 2017 at 7:56 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    go to Napaonline and type in 2005 Tundra Brake Calipers.
    I believe when i looked them up it showed up as 13wl
  3. Nov 19, 2017 at 8:03 PM
    Junetaco03
    I just did that and it showed mine the 13wl and also 13wg I guess I just have to ask for the pads for the 13wl for 2005 thanks! Appreciate the help
    ramonortiz55[QUOTED] likes this.
  4. Nov 19, 2017 at 8:12 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Did some research for this. Found the only difference between the two is where the hard line attaches. Otherwise, they are identical.
    My "research":
    Sicyota04 likes this.
  5. Nov 19, 2017 at 9:59 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    My 13WL 231 mm Toyota OEM calipers came off of a 2006 Tundra 4x4 Limited w/ the 4.7 V8. When I replaced my new pads they were the 5.3" brake pads & 12.5" rotors. I decided to go to a parts store instead of Toyota. The parts store had 2 different sizes to choose from. So I called Toyota and got the Part#'s and luckily the parts store was able to cross reference them. Then I found out that I needed the larger of the two. I also bought @Wheeler's Off-Road Inc brake lines too.
    Hope this helps @Junetaco03 Good luck!
  6. Nov 19, 2017 at 10:07 PM
    Junetaco03
    That did help! Thanks! The person I bought the breaks from didn’t know what year they were he only knew they were from a second gen tundra.
    Sicyota04[QUOTED] likes this.
  7. Nov 19, 2017 at 10:27 PM
    Junetaco03
    Do you happen to know what year & truck (tacoma or tundra) rotors you purchase I’ll be buying rotors and pads Tommorow. Thanks
  8. Nov 19, 2017 at 10:44 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I used 2002 tundra 4x4 v8 is what I ordered mine under.
  9. Nov 20, 2017 at 12:30 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I ordered what I wrote above. 2006 Tundra 4x4 limited. With the 4.7 V8. Be ready for a much larger rotor and you already know about the size of the calipers! Just trim that dust shield and a few other little things. Then you'll be good to go. I'm sure you know the proper backspacing necessary also, when it comes to your wheels. When I installed mine. I wasn't sure if it wasn't going to fit or not with a 16x8" rim and only 4.5" BS.
    It all depends on how the wheel is built. Like if the center of it goes inward or outward. Needless to say my Methid double standards were ok for the job. The 06 Tundra I got everything off of had those really nice Alloy Tundra wheels. I think they were 17". Since the truck was a limited.
