Tundra Brake Mod question
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, Nov 5, 2014.
  1. Nov 5, 2014 at 9:09 PM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I've been doing so research and I kind of got confused. Was trying to get some confirmation on this soon as my brakes are currently shot.
    99-03 Tundra with 12.5" rotors
    S13WE brake calipers
    Corresponding brake pads
    Do I have everything correct?
  2. Nov 5, 2014 at 9:12 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
  3. Nov 5, 2014 at 9:13 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Is it as simple as installing the new rotors and calipers?
  4. Nov 5, 2014 at 9:16 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    Also, you will want a set of these: - braided steel for more responsive pedal feel
    - you don't have to drill out the stock banjo bolt -- these come with the style that perfectly fits both stock tacoma and stock tundra calipers.
  5. Nov 5, 2014 at 9:17 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I think there is something that needs to be done to the brake line fitting. Banjo needs to be drilled maybe? Someone makes one that is a direct bolt on I think.
    ^beat me to it
  6. Nov 5, 2014 at 9:17 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    And trimming the dust shield *slightly* and either drilling the stock banjo bolt or getting the wheeler's offroad braided brake lines, which will bolt right up.
    Very easy job.
  7. Nov 6, 2014 at 3:28 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    What's the benefit? From the driver's seat what difference would you notice?
  8. Nov 6, 2014 at 4:56 AM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Yes I have the 16" chrome clad wheels. So get what I just posted plus those brake lines from wheelers? As for the shield, how would I trim that?
  9. Nov 6, 2014 at 6:28 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    dremel or angle grinder with a cutoff wheel would be my suggestion. You could also use tin snips for a more low-tech approach.
  10. Nov 6, 2014 at 7:41 AM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Will I have to cut off a lot
  11. Nov 6, 2014 at 12:55 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    You only need to trim about a half inch. I used tin snips. Also, you want the '05 Tundra, V8, 4x4 calipers and rotors. You will notice a big difference once the pads seat in. It only took me about 3 hours to do the job.
  12. Nov 6, 2014 at 2:42 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The brake upgarde or the braided line? Obviously the new brakes greatly increase your braking power. The steal lines makes the brake petal stiffer and over all brake response better. Rubber brake hoses will expand with the pressure. Its not a big difference but def worth the purchase.
  13. Nov 6, 2014 at 8:21 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    X2. Not to mention the wheeler's braided lines come with a banjo bolt style that works out of the box with both tacoma and tundra calipers so no drilling or modding required other than bolting the rotors and calipers up and than bleeding the new fluid
  14. Nov 6, 2014 at 8:46 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Well looks like my next paycheck will be going towards this lol. Can I get the rotors and all that from like Autozone or NAPA? And then get the brake lines from Wheelers? Or is there a certain place to buy the rotors, pads, and calipers?
  15. Nov 6, 2014 at 9:08 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    Yep, NAPA is likely going to have the best selection locally. Check out rockauto.com as well. The lines I would get from wheeler's. They are tried and true and verified to work perfectly with this mod.
  16. Nov 7, 2014 at 4:20 AM
    mwrohde
    Sugar Hill, GA
    The brake upgrade. I haven't had a problem stopping my truck. Are we upgrading simply because "If there's a 'better' option I'm going with it"? How much better is the stopping?
  17. Nov 7, 2014 at 5:00 AM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Does it matter if it's double cab or crew cab?
  18. Nov 7, 2014 at 8:29 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Its mostly for ppl that get bigger tires. Especially with 35's, stopping gets harder as you increase the tire size. Also good for ppl that haul and tow.
    For a stock truck, might not be worth the investment :notsure: Depends on your budget and needs really.
    As far as how much better, there was a video that compared two stock trucks and the one with the Tundra brakes stopped substantually quicker than the stock truck. Can't find the video but I can further validate the improvements; with 33" tires, I feel I stop faster than with stock tires.
  19. Nov 7, 2014 at 9:31 AM
    mwrohde
    Sugar Hill, GA
    Good perspective. Thanks
  20. Nov 7, 2014 at 1:14 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I didn't trim the dust shield. Just simply bend it and spin until there's no more contact with rotor. I also drilled out the banjo bolt, but you'll need to get new copper washers if you do this, otherwise the lines will weep fluid.
