Tundra Brake swap parts # question
Discussion in '1st Gen. Tacomas (1995-2004)' started by shortround13, Feb 11, 2015.
  1. Feb 11, 2015 at 9:13 PM
    shortround13
    shortround13 [OP] Well-Known Member
    Sacramento
    04 DblCab TRD 4x4
    just wanted to make sure before I drop a lot of money on all this. found some calipers off e-bay from a 2006 tundra, stamped 13WL (231mm) see a lot of people using 2003-2005 tundra brakes...2006 is still the same correct?
    plan on rebuilding them (cleaning them up, painting and new seals etc)
    rebuild kit part # 04479-60081
    have a way to get discount from toyota so if I went oem
    rotors: 43512-0C011?
    pads: 04465-35290?
    shim: 04945-35120?
    and a set of wheelers braided lines...
    am I missing anything? have correct part #'s?
    thx
  2. Feb 11, 2015 at 9:16 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    Can't verify part numbers, but chiming in to say that the 2006 calipers 13WL are exactly what you're looking for (that's what I'm running on my '04 Tacoma). The wheeler's lines will be perfect and make the job a truly bolt-on mod.
    Enjoy!
  3. Feb 11, 2015 at 11:36 PM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    I bought the same rotors, pads and shims from Toyota and purchased rebuilt calipers from NAPA. Got my info from this thread: Decided to go with the Wheelers brake line kit as well. This thread helped confirm that they would work with the Tundra calipers: http://www.tacomaworld.com/forum/1st-gen-tacomas/240112-tundra-brakes-03-tacoma.html
    More resources on the Tundra Brake Upgrade can be found here in the 1st gen diy list under "Brake Wright ups": http://www.tacomaworld.com/forum/1s...y-how-thread-compiled-list-helpful-links.html
    I plan on installing everything in a few weeks. Will update with info if needed.
  4. Feb 11, 2015 at 11:57 PM
    shortround13
    Sacramento
    04 DblCab TRD 4x4
    Ya i perused most (or all) those threads.
    My biggest question was about the 2006 tundra calipers since evrything else would be ordered based off those. Gonna call toyota tomorrow to confirm the rest of the list.
    Thx for the replies
  5. Mar 18, 2015 at 12:55 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    The LCE kit also includes two short hard brake lines as well as brake line spindle brackets. I'm getting ready to do that mod as well and need to find these items. I'm guessing they might be dealer items.
  6. Mar 18, 2015 at 2:13 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    this is what I'm going off of for when I do my upgrade
  7. Mar 18, 2015 at 3:29 PM
    synergy10
    San Diego
    Did the swap a few weeks ago and am very happy with the outcome. Only issue I ran into was a bad front left caliper. After I replaced it under warranty, the brakes have been squeal free.
    The only thing needing any modification are the dust shields. We had to trim the dust shields at each end of the caliper. Also, we bent the dust shields back in places that touched the rotor. Other than that, it was a bolt on affair.
    Calipers, rotors, pads and shim kit were ordered based on a 2005 Tundra. Wheeler's lines were ordered for a 2002 Tacoma:
    - NAPA (Total Eclipse) Calipers (13WL)
    - OEM Rotors - 43512-0C011
    - OEM Brake Pads - 04465-35290
    - OEM Brake Pad Shim Kit - 04945-35120
    - Wheeler's SS brake line kit
  8. Mar 18, 2015 at 3:39 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Did you need the hard brake lines included in the LCE kit?
  9. Mar 18, 2015 at 4:07 PM
    synergy10
    San Diego
    No. Not with the Wheeler's lines I went with (Tacoma specific, banjo fitting).
    Also, on my friends 99 (3rd gen) 4runner. He was able to use his stock hard lines with 4runner specific (inline fitting) Wheeler's ss brake lines. I'd assume the hard lines in the LCE kit are either from the 4runner or Tundra? Do they mention which calipers they use? 13WG, 13WL?
    In summary, here's how the two (my Tacoma and my buddy's Runner) are setup...
    Tacoma = ss line from bracket on frame, through bracket on knuckle, directly to Tundra caliper via banjo fitting
    4Runner = ss line from bracket on frame to bracket on knuckle, then the hard line from knuckle to caliper via inline fitting
  10. Mar 19, 2015 at 10:14 AM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
    Did the swap about 16 months ago with the LCE kit hard lines, SS Lines, and calipers. I bought Toyota factory rotors locally (shipping cost+++ and tired of aftermaket rotors which do not last), all of the parts in the kit were factory parts except the S.S. lines. One the best upgrades to the truck, it now has brakes like it should of had from the factory and I have no fear of towing my motorcycle trailer.
  11. Mar 19, 2015 at 12:19 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I wish I could find a pic showing the conversion with the hard lines. I can't visualize why some installs can just use the stainless braided lines.
  12. Mar 19, 2015 at 3:22 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    What is the shim kit and fitting kit I wonder?
  13. Mar 19, 2015 at 5:39 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I think it helps with brake squeal and aligning the brakes up, not sure if it's necessary
  14. Mar 19, 2015 at 5:49 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  15. Mar 19, 2015 at 6:32 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    just get loaded reman calipers, around 70 bucks each. and cheap rotors for 25.
  16. Mar 19, 2015 at 6:35 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'm going to vatozone and grabbing mine, take my old ones back for a core return :thumbsup:
  17. Mar 20, 2015 at 8:07 PM
    brother moses
    brother moses Well-Known Member
    Brandon
    Washington
    02 Double Cab Supercharged
    Light Bars, deck plate mod, Camburg 2.5 coil overs, Dakars, AP sliders, NWTI Bumpers
    Has Anybody used the EBC brake kits for said '05 Tundra? It seems they offer a discount for T.W. members, and have slotted rotors and pad combos...
