Tundra brake swap questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by odiesplace, Apr 1, 2017.
  1. Apr 24, 2017 at 10:01 PM
    #41
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Just a vice to hold it.
  2. Apr 24, 2017 at 10:04 PM
    #42
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Subbed for future swap.
  3. Apr 24, 2017 at 10:04 PM
    #43
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yep or a buddy that you trust with some channel locks :D
    mechanicjon[QUOTED] likes this.
  4. Apr 25, 2017 at 5:14 AM
    #44
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Drilling out the end of the bolt isn't something I'd want to do simply holding it by hand.
    I had the best of both worlds... I had a vice and a drill press.
  5. Apr 25, 2017 at 5:52 AM
    #45
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    well that may be the case for you but if OP doesn't have access to a drill press then doing it by hand is possible.
  6. Apr 26, 2017 at 6:46 PM
    #46
    JubeP
    JubeP Member
    LC engineering sells a brake line kit that includes the factory hard lines and brackets that were made for the tundra calipers http://www.lceperformance.com/Stainless-Brake-Line-Kit-Tacom-To-Tundra-Upgrade-p/1055114.htm no drilling or banjo fittings to cast surfaces that aren't machined for them. When I did mine, I used that kit, brembo rotors from tirerack.com, napa calipers , and factory toyota pads and shim kit (forgot part no, it's in the T4R thread) everything bolted right up ( other than cutting the backing plates )
    Dalandser and mechanicjon like this.
  7. Apr 27, 2017 at 2:36 AM
    #47
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  8. May 23, 2017 at 2:42 AM
    #48
    Matic
    Tricky Dick
    Easley, SC
    Sorry if this has been asked but will this work on a 2001 preerunner? I found a set (calipers)of 13wl powdercoated red on cl for $150.
  9. May 23, 2017 at 2:59 AM
    #49
    mechanicjon
    Jon
    Scottsdale Arizona
    What wheels are you running?
  10. May 23, 2017 at 3:00 AM
    #50
    Matic
    Tricky Dick
    Easley, SC
    They weren't on the list.
    "MB Vdrive" 16x8.5
  11. May 23, 2017 at 3:06 AM
    #51
    mechanicjon
    Jon
    Scottsdale Arizona
    !6's you should be okay. Are you running wheel spacers? I'm going to try and make a caliper template tomorrow. That way you can be sure.
    Matic likes this.
  12. May 23, 2017 at 3:16 AM
    #52
    Matic
    Tricky Dick
    Easley, SC
    No spacers. I know the backspacing is molded on the inside of the rim. Not sure what it is though.
    Dalandser likes this.
  13. May 23, 2017 at 9:05 AM
    #53
    Ryan_3TacosIn
    Ryan_3TacosIn Well-Known Member
    Houston, TX
    '02 XTRA Cab, 4x4, TRD- Working on Restore
    OME Shocks, 883 Coilovers, Synthetic Brake Lines, Dakar Leafs with AAL, Baja Rear Bumper; ES Body mount Bushings, Light Racing UCAs, American Racing Wheels w/ 33" Hercules Tires, and more to come...
    Heads up- I have 16's and mine didn't work. I didn't look at the list of "approved" wheels for the Tundra brake upgrade and had this issue:
    https://www.tacomaworld.com/threads/now-that-is-a-conundrum.491648/
    The only way to know for sure is to put it on there and see if it works.
    Matic[QUOTED] likes this.
  14. May 23, 2017 at 9:23 AM
    #54
    mechanicjon
    Jon
    Scottsdale Arizona
    After i make a caliper pattern/stencil this can all be simple to determine if your wheel will fit.
  15. May 23, 2017 at 9:42 AM
    #55
    Ryan_3TacosIn
    Houston, TX
    That would be sweet. Great idea.
  16. May 23, 2017 at 4:00 PM
    #56
    Double Deuce
    Double Deuce Well-Known Member
    JJ
    Sioux Falls South Dakota
    Double Cab 02 TRD
    Can anyone confirm which brake lines to get from wheelers? The Tacoma lines or the Tundra lines?
    I assume the Tacoma lines but want to be sure before I order them. I have all the other 05 tundra parts (Eclipse Napa Calipers, OEM Rotors ,pads/shim kit) waiting anxiously on the shelf to be put to use.
    Matic likes this.
  17. May 23, 2017 at 5:01 PM
    #57
    Matic
    Tricky Dick
    Easley, SC
    Thanks for the heads up. Had a look at your thread and hoping that I don't run into any issues.
  18. May 23, 2017 at 10:25 PM
    #58
    Matic
    Tricky Dick
    Easley, SC
    Picking them up in the morning. Calipers and pads/shims for both sides. $180.
    I guess it's a 50/50 shot as to wether they will work with my rims as they are not on the "approved" list.
    Is it possible to just bolt these up before I get the rest of the hardware to test fit or is there something else that's needs bolted to the caliper that might contact the rim?
  19. May 23, 2017 at 10:35 PM
    #59
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Nope just calipers are fine for test fitting. Two bolts.
  20. May 23, 2017 at 10:40 PM
    #60
    Matic
    Tricky Dick
    Easley, SC
    Also a bit concerned about brake lines. I just had new extended braided lines put on. Someone a few posts back mentions a wheelers kit that shows tundra to Tacoma lines. But it shows it for the "S" caliper.
    Blackdawgs writeup shows that he used standard Tacoma soft braided lines.
    So...im going to have to purchase new lines?
