Tundra brake swap questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by odiesplace, Apr 1, 2017.
  1. May 23, 2017 at 11:40 PM
    #61
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Does your lines have the banjo fitting on the caliper end?
    See the thread I started about 13wl caliper fitment. Download the guide tool and see if you'll clear.
    Buck18 and Matic[QUOTED] like this.
  2. May 24, 2017 at 4:13 AM
    #62
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Can someone tell me how to tell if these are oem calipers or nappa, etc?
    Should they be stamped Toyota or have a Toyota part #?
  3. May 24, 2017 at 5:31 AM
    #63
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    There are a couple different companies selling the red powder coated calipers apparently. They are likely aftermarket company remanned of OEM calipers. Not positive, just noting it has the Yota '13WL' cast into it.
    Matic[QUOTED] likes this.
  4. May 24, 2017 at 5:37 AM
    #64
    Matic
    Tricky Dick
    Easley, SC
    Thx. Picked them up a few mins ago. I believe he said they were "stoptech". ?
  5. May 24, 2017 at 5:45 AM
    #65
    cruiserguy
    Elijah
    SEKS
    Sounds like it. How was price compared to if you bought new yourself? Nice score?
  6. May 24, 2017 at 5:54 AM
    #66
    Matic
    Tricky Dick
    Easley, SC
    $150 for the calipers. I guess that's a fair price. Well under the OME pricing.
    I told him i wanted the pads too, but they were the ones with the bevels on them. So, ill just order the non beveled OEM pads.
  7. May 24, 2017 at 5:57 AM
    #67
    cruiserguy
    Elijah
    SEKS
    Nice, powder coating should help them resist surface rust well too. Akebono makes a lot of the OEM brake pads for Toyota. High quality pads. You're looking for the ceramic ones. You can usually save yourself close to half the cost buying them on Amazon or something.
  8. May 25, 2017 at 3:21 AM
    #68
    Buck18
    Buck18 Well-Known Member
    Buck
    Euharlee GA
    01 Tacoma DC 4wd Limited TRD
    881's on Billie 5100's, Dakar's and 5100's, grey wire mod, 265 75 ko2
    Anyone did this and still using the factory 16" TRD wheels? These are the wheels I'm referring to. IMG_0880.jpg
    Just answered my own question!! Found a link that @mechanicjon posted !! They will fit !! The 4Runner forum has a great write up on this.
  9. May 25, 2017 at 5:05 AM
    #69
    mechanicjon
    Jon
    Scottsdale Arizona
    <-----------on my truck
  10. Aug 12, 2017 at 10:29 PM
    #70
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ima ask a question here real quick.
    Anyone have a link to some cheaper wheels, like procomp or even stock wheels I should be on look for to do this?
    I can't afford to buy a whole new set of wheels so my plan is to buy one here and there till the next time I need new tires, probably next spring/ summer.
    I have tried looking but I just want extra confidence before I start putting the parts together.
  11. Aug 12, 2017 at 10:39 PM
    #71
    mechanicjon
    Jon
    Scottsdale Arizona
    I made a template to check wheels to see if they fit. Any 17inch and most stock 16inch wheels will fit.
  12. Aug 12, 2017 at 10:41 PM
    #72
    mechanicjon
    Jon
    Scottsdale Arizona
  13. Feb 13, 2018 at 2:59 PM
    #73
    stinkyspice
    stinkyspice Well-Known Member
    hey guys. i just ordered some acdelco 05 tundra calipers and ebc rotors and pads. i have the wheelers off road stainless steel lines on the front of my truck. that brake line bolt should work fine for when i install the tundra (13WL) calipers on my 03 4x4 tacoma right?
  14. Feb 13, 2018 at 3:40 PM
    #74
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yes. You'll need two new crush washers per side though (one on each side of the banjo). Four total washers.
    Dalandser likes this.
  15. Feb 13, 2018 at 3:42 PM
    #75
    stinkyspice
    Sick do you guys know the size of the washers by chance. I could call wheelers.but if you guys know
  16. Feb 13, 2018 at 6:44 PM
    #76
    stinkyspice
    I emailed wheelers. But feel free if someone knows. Ha
  17. Feb 13, 2018 at 8:01 PM
    #77
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    You wouldn't happen to know if those rims with a 32 tire could be used as a new spare under the bed?
  18. Feb 13, 2018 at 8:12 PM
    #78
    turbodb
    Dan
    PNW
    AdventureTaco
    32" will be super tight in the spare holder (the four prongs that stick down). It sort of depends on the specific tire whether it will fit. If you're willing to chop off the back two, then it'll fit (assuming it's not too wide). Up to about a 33x10.5 will fit.
    SellyKlater[QUOTED] likes this.
  19. Feb 13, 2018 at 8:16 PM
    #79
    turbodb
    Dan
    PNW
    AdventureTaco
    inside diameter is ~7/16; outside diameter is ~9/16
    mechanicjon likes this.
  20. Nov 5, 2018 at 3:50 PM
    #80
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    X2 my 2001 Taco's bolts were too long
