Tundra brake upgrade,no front brakes now
Discussion in '1st Gen. Tacomas (1995-2004)' started by Smutt, Dec 23, 2023.
  1. Dec 23, 2023 at 10:42 PM
    Smutt
    Smutt [OP] Active Member
    Ron
    04 Tacoma TRD 4DR
    Done the upgrade with rotors and pads from Superstop,calipers were bought locally. Bled several times but almost zero brakes now,before the upgrade when sitting at a stop the pedal would slowly go down. Master cylinder going bad? What else could it be?
  2. Dec 23, 2023 at 11:38 PM
    sarcastictechsupport
    sarcastictechsupport Well-Known Member
    SoCal (805) - Mohave Desert
    2020 Super White TRD OR
    Master cylinder is a main suspect for sinking brake pedal if no external leak is present.
    Calipers bleeder screws - are they on the top or on the bottom of the calipers?
    b_r_o likes this.
  3. Dec 24, 2023 at 7:19 AM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Recheck everything....
  4. Dec 24, 2023 at 7:31 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Probably master cylinder - fluid getting past internal piston seals due to age/wear.
  5. Dec 24, 2023 at 5:30 PM
    Smutt
    Ron
    04 Tacoma TRD 4DR
    They're in the bottom,replaced master cylinder earlier but no change. If you pump the breaks with engine off,you get spongy resistance but never the "back wall" feeling you get when the pedal stops moving forward. Crank the truck,pedal goes to the floor and no resistance at all just all way to the floor. I can still feel the pedal going to the floor like there's a leak. No issue beforehand with old brakes other than the calipers needed attention. Don't get why the pedal goes to the floor as soon as you crank it either.
  6. Dec 24, 2023 at 5:47 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Did you bench bleed the master cylinder before installation?
    Could also be air trapped in the ABS unit, which would require a scan tool with bidirectional control to bleed.
  7. Dec 24, 2023 at 5:56 PM
    Smutt
    Ron
    04 Tacoma TRD 4DR
  8. Dec 24, 2023 at 5:58 PM
    Smutt
    Ron
    04 Tacoma TRD 4DR
    I've changed out everything mentioned before but not as much at the same time and never had problems and it was okay before I did this.
  9. Dec 24, 2023 at 6:07 PM
    The bleed screws on the calipers suppose to be on the top to get the air out of the caliper. Sounds like the calipers are switched right to left, installed on the wrong sides.
  10. Dec 24, 2023 at 6:10 PM
    Smutt
    Ron
    04 Tacoma TRD 4DR
    Never thought about that but did notice the were in the bottom unlike the old ones but didn't realize they would trap air like that tho. Damn it man!
  11. Dec 24, 2023 at 8:11 PM
    LanceRN
    Lance
    And there it is....you have air trapped because the bleeders always need to be on top to allow air to escape. That's why you have such a poor pedal feel, you are compressing air instead of brake fluid.
  12. Jan 12, 2024 at 3:41 AM
    KeezfB
    KeezfB Member
    05 X-Runner
    Bagged
    that caught my attention as well!
