Tundra Brake Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timmah!, Dec 14, 2016.
  1. Dec 16, 2016 at 12:52 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Cool video, very informative. I would like to add that you absolutely must seat the brake pads to the rotor. Not doing this is what results in "warped rotors" which as you mentioned is a misnomer and is actually when you have uneven deposits of brake pad material.
  2. Dec 16, 2016 at 1:39 PM
    Timmah!
    Timmah! [OP] Well-Known Member
    TIM
    I haven't noticed that bleeder on 3rd Gen 4runners but now I'm going to double check and make sure there isn't one there. Thanks for posting the pic.
  3. Dec 16, 2016 at 1:40 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Yeah no idea if it's in the T4Rs, but NP! Thanks for the kick ass video mkay
    Timmah![QUOTED][OP] likes this.
  4. Dec 16, 2016 at 1:44 PM
    Timmah!
    TIM
    Do you have a Bedding-In procedure you could share with us? I know I have the one that is provided in the write-up I refer to in the video description but maybe the method you use is different. This is still one of those things most people don't know about when getting new rotors and pads. I didn't do a bedding in procedure on my 4runner when I installed new rotors and pads and my braking has been pretty good. I get a little shimmy sometimes but nothing like it was before.
  5. Dec 16, 2016 at 2:19 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    What I've read and done is abruptly stopping from 50-70mph but not a complete stop 6-8 times then driving regularly to allow the brakes to cool.
  6. Dec 16, 2016 at 4:29 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    10-20 soft stops at 20, 40, 60 mph then medium and hard at the same speeds. NEVER let the brakes completely stop the truck. I usually work this procedure into daily driving over the first 100-200 miles.
    I suppose I should withdraw my statement of being absolutely necessary. If you have proper braking tendencies then you really only need to use them gently for the first hundred miles or so. Most people don't have proper braking tendencies and just mash the piss out of them till the car stops. In general you want to apply smooth pressure over the time span the brakes are applied. It is also very bad practice to let the brakes completely stop the car. As the car stops you decrease pedal pressure (smoothly) and the car will come to a stop at nearly the exact moment you let off the pedal.
  7. Dec 16, 2016 at 6:28 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    When i was a tech at Chevy dealer the procedure was 3 or 4 medium to hard stops, never letting the vehicle get under 5 mph. Then drive around letting brakes cool for 5 to 10 min. Preferable no complete stops while brakes were cooling.
    And BTW rotors can and do warp, runout and thickness. I've measured +1000's of rotors in my life with a micrometer. It can happen.
  8. Dec 16, 2016 at 8:05 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
  9. Dec 16, 2016 at 9:02 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Nope.
  10. Dec 17, 2016 at 4:52 PM
    Timmah!
    TIM
    So you're saying the rotors actually heat up enough to bend?
  11. Dec 17, 2016 at 11:44 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Ive turned rotors that actually had a low spot in one area before. Like a hole after one pass on a lathe. If i new the history of the rotors i'd say they were after market china rotors That were getting close to min thickness. I'm not discounting at all the material transfer causing most pulsations. But the only way to cure that is resurface the rotor or replace.
    Cheap castiron can have a "MELTING" point of 1200 degrees. Thats melting not getting soft which would happen at a lower temp. Brake rotors have been measured at 1200 on stock vehicles when brakes were abused or under downhill towing conditions.
  12. Dec 18, 2016 at 1:41 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    This is why we make do-it-yourself topics like these.
  13. Aug 28, 2018 at 8:21 PM
    turnerk1
    turnerk1 Well-Known Member
    Keith
    1996 4X X-Cab
    Mystery Lift
    Older thread, I know, but I just did this on my '96. Even after reading a lot, it seems I missed that the earlier master cylinders/boosters aren't optimal for the larger Tundra calipers. I have pretty long pedal travel even after thorough bleeding (including the proportioning valve) and getting no more air. Anyone encountered this and swapped in a later model master cylinder? Is it a bolt in job with maybe a spacer of some sort? Did it help?
    PS: Thanks again, Tim & crew, for your excellent videos.
  14. Sep 22, 2018 at 7:41 PM
    WheelInTheSky
    G
    Jackson Hole
    x2!
    I want to put in a larger MC, the little stock one is only so-so.
  15. Sep 22, 2018 at 8:11 PM
    #35
    lalojamesliz
    lalojamesliz Well-Known Member
    Ed
    02 dbl cab V6 pre-runner trd
    Tundra brake upgrade (in progress)
    Does anyone know of a larger bore mc that would work with minor modification?
  16. Sep 23, 2018 at 12:48 PM
    #36
    mechanicjon
    Jon
    Scottsdale Arizona
    You can put a Tundra master cylinder one a Tacoma. But it requires an adapter. SOS performance brakes makes one. I don't find on their website anymore. May have to call them.
    lalojamesliz likes this.
  17. Sep 23, 2018 at 9:58 PM
    #37
    WheelInTheSky
    G
    Jackson Hole
    This is very good to know, are we talking about an 01/02 Tundra? I'm thinking calipers when asking this question...
  18. Sep 23, 2018 at 10:16 PM
    #38
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @Blackdawg suggested a smaller mc may be the way to go...
  19. Sep 23, 2018 at 10:19 PM
    #39
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Takes some work with the 01-04 model trucks as they use a different booster. Also, I had terrible results in doing so. Would recommend the stock smaller one. Has a better pedal feel anyways.
    Not really. You can just swap a dual diaphragm booster in from an early 1st gen and then it'll bolt right up. I swapped the whole thing over to try a T100 booster. Wasn't worth it anyways.
  20. Sep 24, 2018 at 9:40 AM
    #40
    mechanicjon
    Jon
    Scottsdale Arizona
    Yes it was the early Tundra MC. Matches the 13wL calipers used for the brake upgrade.
