Tundra Brake Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andiamo, Dec 30, 2021.
  1. Dec 30, 2021 at 4:35 PM
    Andiamo
    Andiamo [OP] Well-Known Member
    I put the cheapest QuickStops I could buy from Pep Boys on my truck and they warped so bad within a year the truck shakes when braking. I want to do the Tundra Brake Upgrade with the shiny slotted rotors, but I’d like to do it with Brembo. I don’t want to get a cheap Chinese kit for my truck.
    Is everyone still using the Callahan kit? I’d like to get some Brembo rotors but not sure what size exactly I need. I have an Amazon gift card I’d like to use.
    I have 6-lug 17” rims, will spacers be required to make the upgrade work?
  2. Dec 30, 2021 at 5:04 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Slotted should be fine but if you do any offroading I'd stay away from drilled. No idea if spacers are ever required, but that would be based on caliper and wheel backspacing, not rotor
  3. Dec 30, 2021 at 5:09 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    This page has a great step-by-step guide (with pics) on the upgrade, as well as links to all the parts needed (at varying price points).
    IMO, OEM is best for the pads and rotors, but for the calipers you shouldn't pay the premium. Get them from your local parts store (ideally) or Amazon, which will give a lifetime warranty in case you ever need to replace them (esp. on the trail).
    https://adventuretaco.com/step-by-step-tundra-brake-upgrade-on-a-tacoma-or-4runner/
    Also, don't forget a good brake line kit - can make a lot of difference in brake pedal feel. Plus, the Tundra calipers are designed for hard lines to connect to them, not for a banjo bolt like on Tacomas, so it's good to swap over. If you get red powder coated calipers, you can get matching brake lines too, which is cool.
    You should be just fine with the wheels; nearly all 17's fit. This page has a list of known wheels that do fit for sure (but mostly focuses on 16", since that's where the line is.)
    https://adventuretaco.com/which-wheels-fit-the-tundra-brake-upgrade-on-a-tacoma/
  4. Dec 30, 2021 at 7:24 PM
    Andiamo
  5. Dec 30, 2021 at 7:31 PM
    kctmet
    kctmet Well-Known Member
    Orange County, California
    2017 TRD Sport
    Information on Amazon.
    This product is compatible with:
    Ford F150 Manufactured Between 12/2004 - 2008 - 4WD 6 Lug Models ONLY (Will NOT fit 2WD Models)
    Lincoln Mark LT 2005 - 2008 - 4WD 6 Lug Models ONLY (Will NOT fit 2WD Models)
    Any Questions? Please send us a message or call us at (708) 325-3044.
  6. Dec 30, 2021 at 7:52 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    If you want to buy a Callahan kit, you want one of these two:
    I grabbed both of these links from the step-by-step that I already pasted above, just fyi.
    TACOTU3 and Andiamo[QUOTED][OP] like this.
