tundra brake's
Discussion in '1st Gen. Tacomas (1995-2004)' started by tumbleweed40, Apr 4, 2014.
  1. Apr 4, 2014 at 2:17 PM
    tumbleweed40
    tumbleweed40 [OP] Member
    karl blackman
    moses lake wash
    2006 trd tundra
    stock
    so what all is required for a 2001 Tacoma to have tundra brakes?obviously rotors and calipers pads,but do you need to change any other hard parts?what are the best rotors and pads to use ect.tia
  2. Apr 4, 2014 at 7:08 PM
    michigander
    michigander Member
    Bob
    Frankenmuth, Michigan
    2001 Dbl. Cab TRD 4x4
    I would say the best rotors and pads are OEM Toyota parts. I just did the upgrade about a month ago. So much better! I bought rebuilt Tundra calipers at local auto parts house, trimmeded backing plate and drilled out end of banjo bolt.
  3. Apr 4, 2014 at 8:47 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  4. Apr 5, 2014 at 6:25 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I did this but went to the junkyard and grabbed rotors and the calipers off a truck.
    How much did your spend? For me total cost was 170$ And what did you do with your old calipers and rotors, mine are just taking up space.
  5. Apr 5, 2014 at 2:19 PM
    michigander
    michigander Member
    Bob
    My total cost was about $450. I kept the rotors, possibly might try to put disc brakes on rear. I had to send calipers back for core of almost $100 per side and original was leaking. If I get 115k out of this set of brakes, like the original rotors and calipers. I will be happy!
  6. Apr 6, 2014 at 1:03 AM
    n0ms
    Angel
    San Diego
    I just got the Orginal rotors resurfaced and the calipers I just cleaned and painted.
    Next time I do my brakes I'll get new calipers.
  7. Apr 6, 2014 at 6:56 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    A lot of folks say they have to change the rim size. The tundras brakes aren't supposed to fit under the 15in. rims ?
  8. Apr 6, 2014 at 2:42 PM
    michigander
    michigander Member
    Bob
    If your doing the Tundra brake upgrade, you need to get Tundra brake rotors. They are thicker and a larger diameter.
    To Aquatic Tacoma, Yes you need a larger wheel than a 15"!
  9. Apr 6, 2014 at 4:07 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    I am currently buying parts for the TBU. Ive put out numerous calls to junk yards for Tundra/Sequias and had no luck. I think I am going with Rock Auto:
    All Rockauto parts are from 2005 Tundra 4.7l V8.
    1- $72.50
    1-CENTRIC Part # 14144232 RockAuto $112.79
    1-CENTRIC Part # 14144231 RockAuto $112.79
    2-BREMBO Part # 25534 RockAuto $62.79/each
    Then some carbon metallic pads. Anyone have recommendations?
  10. Apr 6, 2014 at 4:34 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
  11. Apr 6, 2014 at 4:37 PM
    n0ms
    Angel
    San Diego
    Sorry if you misunderstood but I took the rotors from the tundra.
    I'm not that stupid....
  12. Apr 6, 2014 at 6:14 PM
    michigander
    michigander Member
    Bob
    Yes, I misunderstood! I'm new here, so didn't connect that you had found Tundra parts at junk yard. Here is how mine turned out!
  13. Apr 7, 2014 at 12:13 PM
    n0ms
    Angel
    San Diego
    Oh so shiny :)
    I see you didn't go with new brake lines too. Next time I do my brakes I'll do steel lines around (group buy).
  14. Apr 7, 2014 at 12:42 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    What is the performance advantage of upgrading? Is it worth my time to do this?
  15. Apr 7, 2014 at 12:45 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Definitely.
    More power, substantial decreased chance of warping your rotors, substantially reduced brake fade...
  16. Apr 7, 2014 at 3:45 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Nice work! If you find the brakes squishy, get some steal braided lines. Most users found the stock lines didnt work too well with the larger calipers and brake feel was worse than stock.
  17. Apr 7, 2014 at 4:16 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
  18. Apr 7, 2014 at 6:24 PM
    michigander
    michigander Member
    Bob
    The mod that I wanted to do this past winter was an upgrade to the suspension. Then I found a front caliper leaking ,so did the brake upgrade. Going to be getting the OME kit from Wheelers, so was planning to get there braided lines when I get the kit. Otherwise brakes were good before, but even better and smoother now. So glad I went with stock Toyota parts!
  19. Apr 8, 2014 at 1:17 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Will this work on a 6 lug 2WD?
  20. Apr 8, 2014 at 2:35 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yes if you have +16" rims or wheel spacers that allow your rims to clear the larger calipers.
