Tundra info
Discussion in 'Toyota Trucks & SUVs' started by MyTaco, Jan 4, 2010.
  1. Jan 4, 2010 at 10:51 AM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Hey all, I'm looking at a 2003 Tundra for a work truck. Is there a site like this one for Tundras or can you guys help me on some questions? All i've ever owned (and still do) are Tacomas. Just some basics like how good are the 3400 V-6's, what kind of problems are common, etc. Thanks for any help.
  2. Jan 4, 2010 at 11:08 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  3. Jan 4, 2010 at 11:13 AM
    MyTaco
    Az
    08 Prerunner
    thanks tcBob
  4. Jan 4, 2010 at 11:16 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    my god, I am so thankful TW does NOT have all that ad stuff! WOW
  5. Jan 4, 2010 at 11:19 AM
    MyTaco
    Az
    08 Prerunner
    it appears that the 3.4 v-6 is the same one used in the Tacomas also....any problems with it?
  6. Jan 4, 2010 at 11:30 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    none in mine. I asked the toyota service department about that motor as well. They said there are no reoccurring problems with the 3.4. It does have a timing belt that needs changed every 90,000 miles. It is a non-interference motor though so if it breaks the worst that happens is that your stranded. Mine has 155,000 miles on it and have not had to replace anything. I have also overheated the motor and continued to run it overheated for about a half hour. After it cooled down it started right back up and I haven't had any problems with warped heads or leaking gaskets. I'd say that motor is bulletproof.
  7. Jan 4, 2010 at 11:33 AM
    MyTaco
    Az
    08 Prerunner
    good to hear, thanks matthew5olson.
  8. Jan 4, 2010 at 11:35 AM
    BigBawlzTaco
    BigBawlzTaco Well-Known Member
    2019 Toyota Tacoma SR
    X2342345245634
    What the fuck man...
  9. Jan 4, 2010 at 11:37 AM
    matthew5olson
    matthew
    pittsburgh, PA
    If it helps to my father in law has a 02 ext cab tundra. He has the 4.7 in it though. He likes it and it hasn't given him any problems. he misses his taco a lot though. there's only a 1 mpg difference between the v6 and v8 and for all the extra power he wen't with the v8. you can't get a v8 with a standard tranny though if that matters to you. That's one of the reasons my father in law wants to go back to a taco. he loved driving a stick.
  10. Jan 4, 2010 at 11:40 AM
    matthew5olson
    matthew
    pittsburgh, PA
    I love the ad for the chevy silverado that pops up and says:
    The Silverado Stands TallView the Head-to-Head Comparison & Watch the Silverado Rule. Get Info.
    Maybe toyota knows they have that much better of a product that they can take chevy's ad money and know that they are not going to lose sales over it.
  11. Jan 4, 2010 at 11:48 AM
    MyTaco
    Az
    08 Prerunner
    This one's an 03 ex cab w/ 3.4 /5spd with only 74k on it. I'm not sure what kind of mileage these get. I'm used to the 22re in my work truck which I know is much better but I need a bit more power for occasional towing.
  12. Jan 4, 2010 at 12:05 PM
    matthew5olson
    matthew
    pittsburgh, PA
    2wheel or 4. I have a consumer reports account I'm checking their review now
  13. Jan 4, 2010 at 12:06 PM
    MyTaco
    Az
    08 Prerunner
    Cool, thanks...2wd
  14. Jan 4, 2010 at 12:13 PM
    matthew5olson
    matthew
    pittsburgh, PA
    consumer reports has it rated good. they still recomend buying a used one. The road test the did was on a V8 4x4. so the fuel mileages don't apply. They got 15 overall with that setup though. So your gauranteed to get better than that. A 2wd probably weighs about the same as a 4x4 tacoma so the mileage should be around the same. expect about 17-19 overall depending on how you drive, whether yours hauling a lot, and whether its city or highway. Towing with the taco I ussually get 11-15 depending on how big/heavy the trailer is. Hope this helps.
  15. Jan 4, 2010 at 12:18 PM
    MyTaco
    Az
    08 Prerunner
    Thanks again, very helpful and much appreciated.
  16. Jan 4, 2010 at 12:30 PM
    WestonJ
    WestonJ Well-Known Member
    Weston
    Corpus Christi, Texas
    2010 Access Cab TRD Off-Road 4WD
    Added a Tool Box, rear spring TSB, Weathertech floor mats, Emergency lights,
    i had a 2001 tundra for almost 3 years (sold one month ago for a 2010 tacoma). i had zero problems with it. i would definitely still have it, if it was 4WD. They are really good trucks, if you take care of them. I miss mine alot.
