Tundra to Tacoma brake swap feasibily?
Discussion in 'Performance and Tuning' started by DevL, May 24, 2010.
  1. May 24, 2010 at 10:38 AM
    DevL
    DevL [OP] Well-Known Member
    Is it feasible to swap brakes from a Tundra 4x4 with TRAC/ATRAC to replace 2nd Gen Tacoma brakes on a TRD Offroad TRC/ATRAC equipped vehicle? I know the older non ATRAC equipped Tacos could swap to older non ATRAC equpped Tundra brakes but not sure about the ATRAC equipped versions? ANyone ever heard of this being done before?
  2. May 25, 2010 at 8:05 PM
    originalthoughts
    originalthoughts Well-Known Member
    Houston
    1997 Land Cruiser
    None, factory diff lockers are great.
    Forgive my ignorance but are the tundra brakes that much better?
  3. May 25, 2010 at 8:06 PM
    jandrews
    '09 FourDubDee TRD OR
    Tundra brakes are bigger, but I doubt the Taco needs them.
  4. May 25, 2010 at 8:18 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Doesn't the tundra have a different lug pattern. Isn't that why you don't see people rocking tundra rims.
  5. May 25, 2010 at 8:39 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    If I had a Tundra I would use Tundra brakes,If I had a Tacoma,I would use Tacoma brakes.
  6. May 25, 2010 at 8:43 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I assume you are referring to swapping the rear brakes?
  7. May 27, 2010 at 6:54 AM
    silverbullet01
    silverbullet01 Member
    Lonny
    Battle Ground, wa
    01 quad cab trd silver
    3inch revtek coil spacer lift, throttle body spacer, K&N cold air intake, grey wire mod, tundra big brake kit, two 8inch subs behind back seat.
    I have tundra brakes on my 01 dbl cab. I do notice a difference with them. Before I was going through brakes (not just cheap ones). But now they last way longer. Especially if you tow/haul with your Pickup. Their worth the swap imo.
  8. May 27, 2010 at 8:28 AM
    DevL
    Well it appears older Tundras had the same bolt pattern as Tolder Tacomas. The new Tundras are 5 lug. The Tundra brakes are about an inch larger rotor and disk rear. THat would have been a great upgrade along with new pads but it seems like most people are pretty happy with just new pads, lines, and fluid that have lifted trucks.
  9. May 27, 2010 at 8:47 AM
    jandrews
    I really see no reason to mess with a system that obviously isn't broken. The Tacoma's stopping distances are among the best in its class. The brakes don't need upgrading people.
  10. May 27, 2010 at 2:32 PM
    silverbullet01
    Lonny
    Battle Ground, wa
    Upgrading isn't Just for stopping distance, its for the extra life you get out of tundra pads vs stock tacoma, worth it I think. Atleast for automatic trucks that can't just shift down all the way to stop. Example. Me and my brother. Same trucks. I have tundra brakes. he doesn't: since my swap he's wore out 2 sets of pads. I'm still Workin on the first. But as far as swappin in newer tacos. Outta my league.
  11. May 28, 2010 at 6:37 AM
    DevL
    They need upgrading of some sort if you lift and put 33"+ tires, espcially heavy tires like Nittos/Toyos and if you use steel wheels, toolbox, winch, plate bumpers, if you tow heavy loads, etc.
