Tundra TRD Lift?
Discussion in 'Tundras' started by ECUcko, Jan 9, 2019.
  1. Jan 9, 2019 at 10:10 AM
    ECUcko
    ECUcko [OP] Member
    Charlotte
    2015 Black Tacoma TRD Pro
    NFab Nerf Step Bar and Smittybuilt Grille
    I have a 2015 Tacoma TRD Pro. After purchasing it I had asked about adding another inch to the factory 2 inch lift that came on the truck. They basically said all the parts you buy in a TRD pro would have be taken out and replaced to give it a 3 inch left.
    My question is on the tundra. I'm looking to move up. The local dealer has one I like. Its a TRD off road and I am wondering if I would run into the same problem or if a lift is no problem.
    Thanks
  2. Jan 9, 2019 at 10:20 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    yeah, what they're telling you is that there's more to lifting the truck that physically just making it higher......you'll run into all sorts of issues with control arm angles and vibrations if you don't use properly sized parts for the entire setup.
    I can't speak for the Tundra OR specifically, but it'll likely be the same thing. The whole point of the OR and Pro trims is that they've got trim-specific suspensions (and a rear locker) but other than that they're basically the same truck mechanically as the lower trims. You'd be better off buying a lower trim truck and swapping out that cheaper OEM suspension with a full lift kit.
    Not sure how much there is to read up on it here in the Tundra section, but there is a TON of info on lifting in the Tacoma section. Might want to start here. Most of it applies to any vehicle
    https://www.tacomaworld.com/threads...2016-tacoma-presented-by-toytec-lifts.395798/
    Good luck
  3. Jan 9, 2019 at 10:34 AM
    ECUcko
    ECUcko [OP] Member
    Charlotte
    ah thanks for the info. I know nothing about lifting I just like the way it looks. I dont want to get involved with another purchase that I cannot do anything. They are offering me the TRD off road for the same price as one without.
  4. Jan 9, 2019 at 10:48 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    don't forget, they're just trying to make a buck. It's your money, make sure you think it all out. Don't let some salesman pressure you into anything.
    Good luck!
  5. Jan 9, 2019 at 10:51 AM
    ECUcko
    ECUcko [OP] Member
    Charlotte
    yeah I hear you. Not a real fan of dealerships. So it sounds like with a TRD Off Road that lifting it is totally possible just more expensive to have it done than it would be for a non TRD off road model, correct?
  6. Jan 9, 2019 at 10:56 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    well the work and new lift would be the same to put in, you'd just be taking out a more expensive stock suspension than say on a Sport or SR.
    Could work out if you were to sell the old parts? Dealership might not agree to give them back to you though, sometimes they're funny about that stuff. You'd be better off getting a mom n pop shop that you trust to do it for you.
  7. Jan 9, 2019 at 11:01 AM
    ECUcko
    ECUcko [OP] Member
    Charlotte
    That makes total sense. I actually want the Limited. My wife has a limited 4runner so when I get in that then go to my tacoma with the sport cloth its not as nice of a ride. Tundra has the limited and I dont care if has TRD on it, just 4x4
    doublethebass likes this.
  8. Jan 9, 2019 at 11:17 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    sounds like a plan
    not sure about the Tundra Limited, but for the Taco the Limited is basically a Sport with a better interior.......so if it's the same for the Tundra, you're basically taking a Sport suspension off to do the lift
  9. Jan 9, 2019 at 11:26 AM
    ECUcko
    ECUcko [OP] Member
    Charlotte
    I appreciate all the advice and knowledge. This was very helpful! Thank you. Now if you could just come sell my TRD Pro, go negotiate the Tundra, and have it lifted that would be awesome.
  10. Jan 9, 2019 at 12:02 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    haha the last thing i need is another fun truck project
