Tundra wheels on Taco
Discussion in 'Wheels & Tires' started by Tacoe, May 15, 2012.
  1. May 15, 2012 at 7:50 PM
    Tacoe
    Tacoe [OP] Active Member
    Idaho
    09 SR5 4X4
    Will this rim from a 2002 Tundra fit a 2nd gen Tacoma (2009 SR5 DC 4x4) without any modification?
    I think the specs on the tundra wheel are 16x7 15mm offset.
    Thanks.
  2. May 15, 2012 at 7:58 PM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Mine are from an 06 tundra and fit fine on my 12....02 and 06 tundra has same lug pattern so i would say yeah..my tundra wheels actually stick out farther than my tacoma ones did too
  3. May 15, 2012 at 7:59 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    I believe 4wheelin4bangin runs those with his skinnys. Shoot him a pm maybe
  4. May 15, 2012 at 8:10 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
  5. May 15, 2012 at 9:20 PM
    Tacoe
    Idaho
    09 SR5 4X4
    Thanks for the link KenLyns! I think I'll pull the trigger on them.
  6. May 15, 2012 at 9:34 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    I'd still pm him quick cuz his are from a first gen but my guess is that most tacoma/tundra wheels will swap just fine. Don't forget pics when you're done :D
  7. May 21, 2012 at 7:44 PM
    Tacoe
    Idaho
    09 SR5 4X4
    Will I be able to get TPMS sensors for these wheels to work with the Tacoma?
  8. May 21, 2012 at 8:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Offset is not optimal for 2nd Gen, but they will work depending on tire width. I wouldn't throw a set of 285's on them though.
    TPMS should transfer right over from the stock Tacoma Alloys. If you have steel wheels, you'll either need to buy the proper transmitters, or you can get away with rotating the originals 180 degrees, however, any future tire installers need to be aware of that because they will break them.
    Those wheels (2002) did not have TPMS from the factory.
    Toyota's earliest TPMS was around 2004... wife has it on her Rav4, and it's an indirect system... reads from the ABS sensors and it's frankly not very good (a lot of parking lot/mall-crawling triggers the thing).
    Feds didn't mandate TPMS until around 2007 or 2008, so AFAIK, no 1st gen Tundras have it.
  9. Sep 9, 2012 at 8:54 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Sorry to revive old thread. Saw some on local CL and was gonna throw some 285's on. Is the actual rim to skinny for a 285?
  10. Sep 9, 2012 at 9:04 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    265s fit nicely, 285s are a bit over spec... really should be putting them on 8" wide wheels.
    Plus with the 15mm offset, the 285s will likely rub, depending on your lift.
