tundra world .com x runner lowering kit, anybody used it?
Discussion in 'Street Trucks' started by jason smith, Jan 24, 2011.
  1. Jan 24, 2011 at 11:50 AM
    jason smith
    jason smith [OP] loblk08taco
    Tennessee
    08 sr5 2wd 5sp 2.7
    flowmaster 40 series orig flo, cold air intake,painted headlights.Trex eyelids, xrunner wheels, street tacos 3"drop rear, djm 3" drop front
    I have a 2008 tacoma 5 lug tacoma, i was wondering how this kit would change the ride-how quick it would bottom out?
  2. Jan 25, 2011 at 12:42 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    if im not mistaken that's the spring perch, i don't know of anyone that has used it on a regular 5 lug, but the kit is pretty durable and good, although it's not the best drop option handling wise. with 2" blocks and low pro bumps you probably won't bottom out that much.
  3. Jan 25, 2011 at 10:58 PM
    jason smith
    Tennessee
    08 sr5 2wd 5sp 2.7
    i would like to lower it like yours, im on a tight budget,i haul stuff sometimes,400ex mostly, so i cant go too low and i dont want to notch the frame,i thought about that kit with some xrunner wheels,which are for some reason hard to find around here,i need the wheels first because the tires i got now would rub if i lowered it first.ive got the 15s with some oversized tires, the fronts are close now when i turn.
  4. Jan 26, 2011 at 5:38 AM
    pinktaco808
    pinktaco808 Hot Steppa
    o yeahhhh
  5. Jan 30, 2011 at 11:35 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    that's why i mentioned handling. it uses your stock spring, so it keeps your stock spring rate, and only lowers your center of gravity, as well as compressing the strut, vs say upping the spring rate, which would help with the actual handling of the truck. I am not saying this is a bad kit, just explaining what i meant.
  6. Feb 1, 2011 at 8:27 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    rajah dat!
  7. Feb 2, 2011 at 5:43 AM
    pinktaco808
    if you look around there has been alot of incidents where there has been the aluminum blocks cracking
  8. Feb 2, 2011 at 10:45 AM
    jason smith
    Tennessee
    08 sr5 2wd 5sp 2.7
    I work on semi trucks, a peterbilt truck has a aluminum block on the front leaf spring,but its not a pure aluminum its like a alloy.They hold thousands of pounds for a while, but once the road salt and some age takes over ive seen them come in cracked or with pieces missing, thats what i would be worried about with this kit,corrosion.
  9. Feb 2, 2011 at 8:44 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    yep the main beef about aluminum blocks that i have is the way theyre made...and the quality of aluminum that theyre made of.
    most aluminium blocks you find are like the second example in ryan's post. the pins in the middle have a nice tendency to shear off lol
  10. Feb 2, 2011 at 10:38 PM
    pinktaco808
