Tundy, house and beetle build thread...and exploring.
Discussion in '2nd Gen. Builds (2005-2015)' started by Stig, Dec 28, 2015.
  1. Jun 20, 2017 at 5:49 PM
    #621
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
    Turd. Shoulda told me! I would have done them for you this morning
  2. Jun 20, 2017 at 6:20 PM
    #622
    Stig
    Stig [OP] Resident smartass
    Brandon
    Ta no mo
    Didn't expect them to need turned already...
    Just got them back on, manually adjusted the rear until they started to drag but the parking brake doesn't work anymore. Apparently i must have to manually adjust the parking brake under the console? :frusty:
  3. Jun 20, 2017 at 6:24 PM
    #623
    lobsterbait
    Not Paul
    Parker CO
    Goose
    Isss everything connected? If it was working before and not now, It had to have been doing the install, possibly when you did the shoes?
  4. Jun 20, 2017 at 6:37 PM
    #624
    Stig
    Brandon
    Ta no mo
    Yeah... I am adjusting the thing under the console but I'm almost out of adjustment now.
    I put it all together, spun the wheel until the shoes started hitting the drum on each side. Then put it back together, drive it forward and back, brakes worked.
    Parking brake easily went to the floor, no drag. Popped the center console, adjusting the mechanism under there and i now am able to get it to grab, wheels in the air i can push the pedal all the way down and am still able to turn the wheels by hand (there is a bit of drag). But I'm almost out of length on the adjuster rod thing.
    @thefatkid
  5. Jun 20, 2017 at 7:09 PM
    #625
    lobsterbait
    Not Paul
    Parker CO
    Goose
    Yea I think something must have gotten messed up. I dont think you should have to adjust from inside the truck in this situation
  6. Jun 20, 2017 at 10:21 PM
    #626
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Generally all your brake adjustment should be done at the rear drums. The cable tension should be set with the drums off visually watching the parking brake struts.
    My guess, you did one adjustment and didn't pump the brakes to settle the shoes then adjust again?
  7. Jun 21, 2017 at 3:46 AM
    #627
    Stig
    Brandon
    Ta no mo
    I adjusted both of the star wheels until they started to drag. Put wheels on, pushed the pedal while in the air and they still had the same drag.
    Put it on the ground and went forward backward, then noticed the parking brake was useless.
    When i jacked it up again after realizing that the center console adjustment bottomed out, i loosened that adjuster again and I checked the star wheel adjustment to follow the "lock up the drums and turn back 15 clicks" way and saw that I had to adjust them again quite a bit before they started to drag.
    So they currently have a little bit of drag, should i back them off until they have zero drag? A ton of wind and some rain blasted through and i gave up for the night. The drag on both sides is not uniform... They'll drag a little on both sides almost as if the drums aren't round (it's done this since the first time I checked them). It'll have a tiny bit of drag then nothing, then touch at the same part of the rotation.
  8. Jun 21, 2017 at 7:36 AM
    #628
    thefatkid
    Brian
    Colorado
    2004 thingy
    Some drag is normal. I don't use the back off method, more of a feeling of brake pedal and parking brake pedal travel. With the tire on the brakes should drag enough to prevent a full revolution, you would really like to see 2.
    New brakes will not have a good hold until the brakes are bedded in.
    Stig[OP] likes this.
  9. Jun 22, 2017 at 2:55 PM
    #629
    Stig
    Brandon
    Ta no mo
    Ok, thats basically what I set it to... and braking feels much better now! And no more nasty squeal from the rear.
  10. Jun 22, 2017 at 2:59 PM
    #630
    Stig
    Brandon
    Ta no mo
    My landlord put the idea in my head for some way to get out onto the water whenever I camp near a lake/calm stream.... Then the other day when I was killing some time at a park, curiosity got the best of me and I checked out what Amazon had to offer. I found a pretty reasonably priced board. And I had a decent amount of points waiting to be spent, the rest is history.
    It arrived today, comes with everything you need. Seems pretty solid for the price. At 10ft its an "advanced" board for my height/weight, but I'll be there soon enough.
    HydroForce 10ft Inflatable Paddle Board
    And it does store nice and small. Everything is in the bag. Now i just need to make space for it in the truck. :annoyed:
    kashtyaatsi and lobsterbait like this.
  11. Jun 22, 2017 at 7:09 PM
    #631
    Stig
    Brandon
    Ta no mo
    "The reasons you're not following your dreams today will look a whole lot more like excuses tomorrow."
    Too good not to share. Stolen from Expedition Portal's FB post.
  12. Jun 22, 2017 at 8:03 PM
    #632
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    You sir are a good man. I wish I had some youth back to do what you are about to do.
  13. Jun 22, 2017 at 8:28 PM
    #633
    Stig
    Brandon
    Ta no mo
    Never too late! Just a little more difficult. :D
  14. Jun 22, 2017 at 8:31 PM
    #634
    Gramps
    Gramps
    07 TRD DC 4x4
    I digress....
    Stig[QUOTED][OP] likes this.
  15. Jun 22, 2017 at 8:35 PM
    #635
    Stig
    Brandon
    Ta no mo
    @Star-Lord will be joining me soon!
    Deathbysnusnu likes this.
  16. Jun 22, 2017 at 8:43 PM
    #636
    Gramps
    Gramps
    07 TRD DC 4x4
    Stock up on Depends. I guarantee he will not pack enough. :D
  17. Jun 22, 2017 at 8:55 PM
    #637
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I pan to roam naked through the forest and let nature take it's course.
  18. Jun 22, 2017 at 10:06 PM
    #638
    Stig
    Brandon
    Ta no mo
    Well, I guess he wont be joining me after all!
  19. Jun 23, 2017 at 9:15 AM
    #639
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Holy shit, it works. I'm currently connected via the Mobley, powered via USB direct from the Chrome Book and the house WiFi is turned off.
    jubei and Stig[OP] like this.
  20. Jun 23, 2017 at 9:17 AM
    #640
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    slow as fuck too sitting in the living room. 4 mbps download, 2.02 upload. :rofl:
