Tune questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by marcamos, Nov 25, 2021.
  1. Nov 26, 2021 at 7:49 PM
    #61
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I’m not trying to be a jerk here. I’m legitimately curious. Another hard issue to crack is getting above 85% load in 4th gear with gear lock on a Dyno to get a full detailed dyno run. Maybe you’ve already solved this as well. Looking forward to the data
  2. Nov 26, 2021 at 7:56 PM
    #62
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Pulling over 100% on the street in 4th. Not sure why we couldn't hit 85% on a Dyno. I guess we'll see soon.
  3. Nov 26, 2021 at 8:06 PM
    #63
    Mooseditty17
    AJ
    WI
    101.96% load @ 6009 rpm in 4th gear is 109.92 mph on 34s.
  4. Nov 26, 2021 at 8:08 PM
    #64
    Montana_Actual
    Montana_Actual ;)
    Does the tune change timing? My only concern would be running lean.
    I plan on getting one after I get the gears installed. But I don't want to have to run 91.
    I also have no idea where to go in Montana. I'm actually curious if my dealer would do this, because they do everything else. They legit don't care. Montana has consumer rights. You do what you want.
  5. Nov 26, 2021 at 8:08 PM
    #65
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Great, get that shit on the rollers. Should be huge.
    Mooseditty17 likes this.
  6. Nov 26, 2021 at 8:14 PM
    #66
    Mooseditty17
    AJ
    WI
    No need for 91. Ignition and valve timing changes have been made. We're pushing limits, not crossing boundaries. One we're finished Dyno testing we assume some adjustments may be necessary, then we'll release. We plan to provide a network of people to offer our tune nation wide.
    MOC221_, ktbell444 and FCL30 like this.
  7. Nov 27, 2021 at 4:09 AM
    #67
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Are you working on a dedicated M/T tune?
  8. Nov 27, 2021 at 4:47 AM
    #68
    Mooseditty17
    AJ
    WI
    There will be M/T tunes available as well
    MOC221_[QUOTED] likes this.
  9. Nov 27, 2021 at 5:23 AM
    #69
    MOC221_
    Frank
    Right on, looking forward to more files for M/T (not just ports, though).
    I'm currently on a calibration version (04B42) that doesn't have support in the form of an actual tune pack (well, no support in the lowly vF community, not sure what the Pro tuners have in their toolbox).
  10. Nov 27, 2021 at 7:43 AM
    #70
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    2.0 will run fine on both octane. I've done it. OL works. My post on VF forums were not about 2.0. They were about adjusting for knock with the goal of running a cleaner KCLV than stock values. Changing engine timing increases the likelihood for knock and detonation, but I digress... This wasn't about my post on knock. It was about OL on 2.0 which IS a thing. Yes, KCLV will drop some, then stabilize. This is the ECU doing its job. KCLV drops because the ECU is retarding timing to prevent knock and detonation. Was a long discussion about this on fb and Mat chimed in for set things straight. Long story short, there is special coding written in for OL.
    FCL30 likes this.
  11. Nov 27, 2021 at 7:47 AM
    #71
    Kevinpd325
    Kevin
    San Diego
    Ours does, most others do not. These truck run rich AF. Leaning them out isn't a bad thing.
  12. Nov 27, 2021 at 11:24 AM
    #72
    marcamos
    marcamos [OP] Well-Known Member
    Marc
    Beverly, Massachusetts
    2021 Off Road 6MT
    This is how I feel trying to understand most of this thread:
  13. Nov 27, 2021 at 11:32 AM
    #73
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Op, I apologize because we basically hijacked your thread.
    But, if you do have any other questions, feel free to continue asking. Plenty of knowledge on the forum.
    Mooseditty17 and marcamos[OP] like this.
  14. Nov 27, 2021 at 11:37 AM
    #74
    marcamos
    Marc
    2021 Off Road 6MT
    Hah, nah, totally fine!
  15. Nov 27, 2021 at 12:31 PM
    #75
    marcamos
    Marc
    2021 Off Road 6MT
    Hmm, I’m pretty comfortable with computers (I write Javascript for a living); is there a decent place to learn about doing this myself?
    ktbell444 likes this.
  16. Nov 27, 2021 at 12:41 PM
    #76
    Mooseditty17
    AJ
    WI
    Mooseditty17 has a thread on getting the basics
    Kevinpd325, Tacotoast and ktbell444 like this.
  17. Nov 27, 2021 at 12:43 PM
    #77
    Mooseditty17
    AJ
    WI
    ktbell444 and marcamos[OP] like this.
  18. Nov 27, 2021 at 3:20 PM
    #78
    SpeySquatch
    2016 TRD OR DCSB
    yah, are those temps showing from a stock transmission cooler running that data? I meant not the first time because with a stock cooler after a few WOTs usually it is a bit warmer than that
  19. Nov 27, 2021 at 3:28 PM
    #79
    Mooseditty17
    AJ
    WI
    Ah... Well depends how long you let it cool between pulls. Mine is factory. Once TC locks up it cools down pretty quick.
  20. Nov 27, 2021 at 7:04 PM
    #80
    marcamos
    Marc
    2021 Off Road 6MT
