Tune Up Complete?
Discussion in '1st Gen. Tacomas (1995-2004)' started by matthewryan9, Mar 20, 2014.
  1. Mar 20, 2014 at 10:24 PM
    matthewryan9
    matthewryan9 [OP] Member
    Huntington, WV
    02 Dbl Cab SR5 TRD 4x4
    Hello everyone,
    Just got done giving my recently purchased Taco a tune up. Anything else you guys have in mind that I don't have listed? Also, timing belt was recently replaced before I bought it.
    Maintenance Completed:
    Oil change/filter
    Air filter
    Spark plugs (wires were good)
    Coolant flush/refill
    Front & Rear Diff. oil change
    Transfer Case oil change
    Auto Trans fluid was nice and red - still may flush/refill
    Also, picked up a new Gibson cat back on Amazon for 225 with free s/h - of course I had to tell the wife it was more of a maintenance reason.
    Anything else with these trucks that require routine maintenance? Thanks for any help.
  2. Mar 21, 2014 at 3:41 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    I would make sure to hit grease fittings. Don't know if you rotated tires either. Good view of brakes,calipers,etc.
  3. Mar 21, 2014 at 4:12 AM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    Clean the MAF sensor and the Throttle Body.
  4. Mar 21, 2014 at 5:36 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    How many miles on the trans fluid? How many miles on the truck?
    If I bought 2nd hand and it had a auto, I would change that out on a initial service, just for my peace of mind. Depending on what I see in the pan would determine if it needed a flush or not. Bright red fluid on the dipstick does not always denote a happy trans.
    Spare tire and jack in good shape?. One thing that is always overlooked until it's needed.
  5. Mar 21, 2014 at 8:52 AM
    matthewryan9
    Huntington, WV
    thanks for the input guys,
    next day off ill continue the tune up.... truck has 162k
    ill finish off all the fluid changes asap, spare/jack are good, frame is in good shape too, very minimal rust
  6. Mar 21, 2014 at 12:17 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    PCV valve
  7. Mar 21, 2014 at 12:27 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    agreed with the suggestions above and also check the lower ball joints for excessive play. there was a recall on the 01-04 tacomas.
